Home > Puma (Tdci) > Puma half shafts
Page 3 of 5 <12345>
Vitesse
Update: fitted the britpart one piece shafts today. No problem at all and have made a huge difference to the driveline. NS flange splines were far worse than OS interestingly.
Smile 2015 90 XS Santorini Black
Post #750759 12th Jan 2019 7:30pm
Good job. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #750760 12th Jan 2019 7:33pm
doublea
Scotland 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
Britpart items fitted to my sister’s 90 maybe 2 months ago. Might be worth considering some corrosion protection, she’s not worried about minor cosmetics though!
Although the winter has not been too bad yet, there’s been plenty of road salting around here since around October. Current Steeds:
2015 110 UW in Grasmere Green
2003 BMW F650 the Hack
2000 Elise
1992 Ducati 888 (no longer in bits, yahoo)
1990 TDR 250 (in bits again)
1988 TDR 250 (no longer in bits) and for sale
Post #750778 12th Jan 2019 8:50pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Hmm - I painted mine in quite a few coats of satin black before fitting. No sign of corrosion.
Post #750783 12th Jan 2019 9:01pm
Vitesse
Good point ! I will do something to keep the Corrosion at bay. Thumbs Up 2015 90 XS Santorini Black
Post #750785 12th Jan 2019 9:04pm
Do Britpart do an equivalent to the 110 shafts? (LR072977 & 072976)
Sorry, just found them on island4x4 (https://www.island-4x4.co.uk/halfshaft-rear-britpart-tob500030-lr072977-p-37449.html)
HMmm double edit; these seem to be for a 90, not 110
triple edit.... island4x4 show the same part number for a 110 also (https://www.island-4x4.co.uk/halfshaft-rear-110130-britpart-tob500030-lr072977-p-37448.html)....
I was under the impression 90's were different from 110/130 ones...
Post #750850 13th Jan 2019 12:12am
Devon-Rover
The shafts are the same on the rear. same PN for both since 2004 IIRC Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #750861 13th Jan 2019 1:22am
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
Could you use Buzzweld (same as the rear crossmember kit) to protect them, and spray them before fitting? Keith
Post #750905 13th Jan 2019 11:53am
Vitesse
I think I am just going to smear them with coppaslip like the road wheel flange facing.
That’s should stop it getting bad. Thumbs Up 2015 90 XS Santorini Black
Post #750917 13th Jan 2019 12:50pm
Keith5
There's always something needing done......
Inspired to go and check mine having read through all of the discussion, now added to the list of things to be done when the weather is a bit warmer. Keith
Post #750923 13th Jan 2019 1:28pm
Dobby
That's just what I did this week. Found that both sides are worn, OS more than NS. Got britpart onepiece replacements as they where about £50, compared to £350 each for genuine!
Looks like a case of whip out the old and slap in the new.
Post #750941 13th Jan 2019 2:20pm
The OS was more worn on mine too on the rear, seems to often be the case regardless of 1piece or two.
Since I replaced mine with Ashcroft all around. (Except CV's etc.) mine has been transformed.
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #750943 13th Jan 2019 2:29pm
The offside shaft on a Defender will almost always wear faster and be more likely to break than the nearside due to being shorter and hence less elastic. There will be the odd exception but in general this will be the case.
Post #751131 13th Jan 2019 11:57pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Funny you should say that, because that's what happened to me a few weeks back. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #751136 14th Jan 2019 12:11am
I wonder if roundabouts maybe anything to do with it? After all there are a lot of them.
After all the NS would spin that bit faster and the OS that bit slower in a clockwise roundabout.
Is there the same occurance on the front on a regular basis? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #751176 14th Jan 2019 12:16pm
Page 3 of 5 <12345>
