Home > Maintenance & Modifications > Corrosion Prevention Guide!
Page 48 of 89 <123 ... 474849 ... 878889>
Zagato
I need to sort a new picture hosting site to show you a lovely low mileage base spec 90 in Keswick Green bought from JCB,s fleet. I have three in at the moment, one of which is a 65 plate white 90 with only 300 miles on the clock Shocked it is as new of course... Cool
Post #660246 29th Oct 2017 12:48pm
As has been said lots of times, host them on here. Darren
Post #660247 29th Oct 2017 1:01pm
Zagato
I thought there is only a certain amount of capacity on a forum to host pictures, on other forums once there is a limit then others cannot post up pictures.
I will put them up however...
300 miles on the clock!
Sorry to other clients but I don,t remember to take a pic of them all.
Post #660257 29th Oct 2017 1:49pm
Martin hasn't applied any limits yet and even if he does, he's quite approachable Wink Darren
Post #660259 29th Oct 2017 2:05pm
Zagato
Year old Discovery rusting already Rolling Eyes now treated Very Happy
Heritage
Post #660260 29th Oct 2017 2:05pm
Zagato
One of the fastest track MX5's in the country!
This was nice, base spec 110 Very Happy
Post #660265 29th Oct 2017 2:13pm
Zagato
Something LARGE for a change! Waddy,s camper...
Post #660267 29th Oct 2017 2:23pm
Zagato
Good time to get your vehicle done before the winter salt hits the roads folks, salt just eats metal Sad Perhaps that is why I get so many Defenders from the Midlands! CCalvert@CCAutomotive.co.uk for a quote or just advice if you fancy a go at rust proofing yourself. Thumbs Up
Post #660269 29th Oct 2017 2:26pm
Jerry
2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
Hello,
I have just treated the bulkhead with Dinitrol cavity wax and used the supplied extension pipe through the redundant wiper holes. Could I ask, the cavity that I got the extension pipe into is very narrow and just runs along the top. Are there drainage holes in that cavity to then let the wax drop into the bulkhead? (sorry if this is a dumb Q). Or is there a better way of getting access?
thanks,
Jerry
Post #661564 3rd Nov 2017 12:21am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
You can take one of the door hinge bolts out to get better access. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #661565 3rd Nov 2017 12:37am
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
And also up through the drain hole at the bottom of each A pillar to give them a good coating. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #661574 3rd Nov 2017 6:51am
Zagato
Just a reminder to those who have TD5's, I had a phone call from a guy who poked his spray extension into the false wiper spindle hole and unseen sprayed his dash, passenger seat, door and roof with a generous coating of cavity wax Shocked
On the same theme careful when you do a 'B' post on a 110 from the drain hole, or it will spray all over your seat side. Don,t forget to do the other hole further back by taking out the bung under the triangular panel with rivets on a 110. It is where all the muck gets inside, so clean/flush out first of all Thumbs Up
Post #661606 3rd Nov 2017 10:23am
Jerry
thanks for the advice.
Just to clarify - the cavity accessed from the redundant wiper holes - it is very narrow and appears to just run along the top. Are there drainage holes in that cavity to then let the wax drop into the bulkhead?
thanks
Post #661623 3rd Nov 2017 1:00pm
Zagato
Jerry when you pump loads of product into those holes it pours out beneath the double skin at the top of the bulkhead engine bay side. As Mash and Nosnibod say the important part is the top of the 'A' post. The lower part of the bulkhead can be accessed from engine bay and underneath e.g. Footwell areas and around the back of the engine. I use mostly Dinitrol Corroheat for around the back of engine area pictured above on near new ones and good condition street only examples as again you don,t want to plaster black mucky underseal on thick as you want to keep an eye on it over time, it looks smarter, pretty invisible actually and it doesn,t matter if it gets on any hot part of the engine as it was designed for engine protection/detailing.
The above picture comes from a 300 mile example just gone, so have taken a few pics as it is easy to see in pics in white for demo pic purposes. I have another coming in this Friday with delivery miles only on it Shocked
Post #663650 12th Nov 2017 10:35am
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
Hi Zagato
The one arriving on Friday will be mine another Landmark but in Montalcino red.
You have taken some great photos of defenders I particularly like the Heritage green 90 van.
Post #663698 12th Nov 2017 2:17pm
