Home > Puma (Tdci) > nasty whistle from turbo/manifold |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Is the vehicle re-mapped ? 130's have feeling's as well you know
16th Jan 2011 9:42pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
it is but currently runing it without it even so there still must be a way ? 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
16th Jan 2011 9:44pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2599 |
Have you checked the turbo inlet hose? It tends to rub against a bolt and develop a leak, leading to the whistling sound.
16th Jan 2011 9:46pm |
This is the problem I expect.
http://www.defender2.net/forum/topic457.ht...t+manifold 130's have feeling's as well you know |
interesting did you ever resolve it with new gasket or anything what was the result? 2015 2.2 tdci hardtop xs
16th Jan 2011 10:02pm |
RLD Member Since: 29 Jun 2007 Location: Lancs Posts: 858 |
i had this on my TD5 130 as i do have a tune on it it had expanded the manifold and bust off bolts and twisted the manifold so had J&E fix it with a new one with some sort of expansion thingy in bob on no problem RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
17th Jan 2011 5:36pm |
New manifold put the car back to standard and sold it. 130's have feeling's as well you know |
17th Jan 2011 5:49pm |
ok well i certainly done want to sell it i want a decent solution
cheers steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
17th Jan 2011 8:16pm |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
Exhaust manifold warping on TD5s is a known problem - especially when tunde due to the extra heat. I had the 90 done in December and the 110 was done earlier last year. John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
24th Jan 2011 3:14pm |
defender75 Member Since: 06 Nov 2010 Location: Germany Posts: 219 |
Is the whistle harmful? My puma whistles or sounds likes an ambulance is behind me at times. I just thought it was the normal turbo sound
24th Jan 2011 4:01pm |
its the result of possible warped manifold or turbo flages and/or the gasket between them
the first time i took it to the dealer they replced the gasket and bolts and said they were loose ? its now in 12month on being checked again steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
24th Jan 2011 4:30pm |
We've had the manifolds skimmed on both the Raiders - I was advised to skim them rather than replace them as once they warp due to the heat they shouldn't do the same again. John
24th Jan 2011 5:00pm |
hmm, that does sound like a warped exhaust manifold. A tell-tale sign is black soot around the manifold |
24th Jan 2011 5:04pm |
on td5 the temp is higher than on a a puma
i will u let u no wat the dealer say abt the manfold to date only the flange that bolts to turbo on pumas warp ? 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
24th Jan 2011 5:17pm |
