Home > Puma (Tdci) > Puma fuel bleeding pump
Page 3 of 11 <123 4 ... 91011>
dgardel
Italy
Post #39956 6th Sep 2010 2:17pm
K9F
AndrewS wrote:
Here is the contents Shocked Check out the crap in the bottom of the glass.
Off Topic From where I'm from that looks like a half decent glass of 'central heating for tramps' (cider) and good enough to guzzle!
Laughing
Gotta be said Andrew you do come up with some brilliant solutions and quick fixes. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #39957 6th Sep 2010 2:22pm
Bomber82
Italy 2009 Defender 110 Puma 2.4 SW Zermatt Silver
dgardel wrote:
I bought it from a diesel injection workshop for 22,00€ (build from DEPLHI).....
Matteo,
1 pollice (1") = 25.4mm
ma il disegno è già in mm............................
The quotes are still in metric
oh cavolo.... Shocked
ho proprio bisogno di ferie.... Rolling Eyes
I need vacation....very urgently!!!! Big Cry Matteo
Defender 110 Td4 SE MY 09
Post #39958 6th Sep 2010 2:29pm
dgardel
Italy
Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #39959 6th Sep 2010 2:33pm
ickle
plastic connector
The outlet on a Freelander 2 fuel filter cartridge appears to be the same as the one required. With a bit of inginuity and a bleed bubble (rover 25 diesel?) should be possible to make something for very little cost.
Does anyone know the easy way (apart from paying someone else) to change the oil filter on a F2 without getting warm oil down your arm?
Confused
Post #40896 19th Sep 2010 9:55pm
zebra
Italy 2008 Defender 110 Puma 2.4 SW Alpine White
AndrewS wrote:
The home made one works Razz
Removed and drained the filter. Here is the contents Shocked Check out the crap in the bottom of the glass.
This is the pump I made. As you can see there is only one connection on the 'tool' as I never connected the bleed tool in line. I simply placed the end of the pipe into a container to catch the fuel as it was pumped through. The other end was pushed into the female connector of the fuel line. It took about 2 minutes and about 2 pints of fuel before the fuel became air free.
Here is the Land Rover tool
A picture with dimensions of the male end of the Land Rover tool.
A picture with dimensions of the male end of the home made tool. As you can see its smaller in diameter but it sealed. Obviously I would like to get an end that is the correct Ø
This is the location of the connector that the bleed tool fixes to. Push the blue tabs in and pull the connector off the feed to the fuel pump.
Disclaimer
If you Censored your car up following these instructions its not my fault Razz Razz
Hi, I've bought a bleeding pump on ebay (http://cgi.ebay.it/DIESEL-ENGINE-FUEL-PRIMING-PUMP-/110475636037?pt=UK_Measuring_Tools_Levels&hash=item19b8dc6d45#ht_2098wt_912) the male connection has the same dimension of the land rover tool, only the transparent rubber pipe length is shorter.
But I have a doubt, can you explain me which is the correct direction of the fuel in the pump???? In my pump the direction is from the male to the female connection (there is an arrow on the pump..) while in the AndrewS post, I’ve understood that he take the fuel from an external tank and pump it in the fuel circuit across the male connection. this is just a problem of my bad English Embarassed ??????
Ciao
Lorenzo
Post #41381 27th Sep 2010 11:13am
Bomber82
Ciao Lorenzo, your pump is correct!!the flux is from the male to female.
You must pump the fuel until there are more bubbles! Thumbs Up Matteo
Post #41388 27th Sep 2010 1:17pm
zebra
Thumbs Up thank's matteo
ciao
Lorenzo
Post #41394 27th Sep 2010 1:46pm
Naks
Bundubasher wrote:
Just for interest sake. I have replaced the diesel filter fiter about four times and I have never had to bleed the system at all. I just start the engine and let her idle for 3 minutes. Never had an air lock or anything like that. Engine has never missed a beat after starting after a filter change.
Did you fill the new filter with diesel before replacing it?
Post #41516 29th Sep 2010 8:27am
dgardel
Italy
always!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #41542 29th Sep 2010 1:02pm
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
Here is my input (at 40 000 km):
Cheers! Janusz
www.yahodeville.com
Post #42054 6th Oct 2010 10:38am
Naks
yaho wrote:
Here is my input (at 40 000 km) Cheers!
Is that from draining the filter in the rear wheel arch? Shocked
Post #42063 6th Oct 2010 11:16am
yaho
Yes, the cup size is c.a. 200 ml Janusz
www.yahodeville.com
Post #42070 6th Oct 2010 11:46am
yaho
Just finished the job with the bleeding pump.
There is no need to have any connector on both sides of the pump:
- female end goes straight to an empty container
- initially I have tried male connector but I could not have a good sealing - end of the pipe changed to 10 mm (outside diameter) solved the problem - fits there with perfect sealing Janusz
www.yahodeville.com
Post #42084 6th Oct 2010 2:51pm
Naks
Did you try putting the filter back without doing this bleeding thing? If so what happened?
Post #42086 6th Oct 2010 2:58pm
