Home > Technical > Brake Calliper multispline bolt size
Having a blonde moment and can't recall the size
Help appreciated Thumbs Up
Post #355744 4th Sep 2014 9:47pm
munch90
14mm I'm sure
Post #355755 4th Sep 2014 9:59pm
landy andy
Thumbs Up 14 mm
Post #355778 4th Sep 2014 11:19pm
jimbob7
12 point socket Wink Pov.spec,ftw. 2006, 110,TD5.
Post #355784 4th Sep 2014 11:36pm
Thanks all Thumbs Up for some dumb reason I had 1/2 inch in my head Rolling with laughter Rolling with laughter
Post #355799 5th Sep 2014 4:12am
kevinf
never worked on a puma, but every tdi and td5 brake caliper bolt as been 13mm bi hex(12 point)
Post #355832 5th Sep 2014 10:11am
^^^^ +1
Post #355833 5th Sep 2014 10:20am
jimbob7
Ring spanners are 12 point,someone go looksy,I too also can't remember,other than 1 was Censored tight. Pov.spec,ftw. 2006, 110,TD5.
Post #355843 5th Sep 2014 10:49am
munch90
munch90 wrote:
14mm I'm sure
wrong !!!
13mm
Post #355846 5th Sep 2014 10:56am
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Munch is correct, It is 13 mm ...
But 1/2" AF Bi-Hex [12 point] fits better Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #355849 5th Sep 2014 11:05am
landy andy
Ahhhh. Yes it's the axel ends that are 14mm hex Embarassed Embarassed
Andy
Post #355851 5th Sep 2014 11:17am
So not so dumb then Thumbs Up
Complete brake overhaul on the 50th coming up pipes callipers discs n pads Thumbs Up and new bolts were needed
Post #355959 5th Sep 2014 9:23pm
NickMc
13mm you are thinking of the bolts that hold the discs to the hubs which are 14mm.
Post #361571 1st Oct 2014 11:00pm
