Home > Technical > Brake Calliper multispline bolt size |
14mm I'm sure
4th Sep 2014 9:59pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5460 |
14 mm
4th Sep 2014 11:19pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
12 point socket Pov.spec,ftw. 2006, 110,TD5.
4th Sep 2014 11:36pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Thanks all for some dumb reason I had 1/2 inch in my head
5th Sep 2014 4:12am |
kevinf Member Since: 12 Apr 2011 Location: sheffield Posts: 55 |
never worked on a puma, but every tdi and td5 brake caliper bolt as been 13mm bi hex(12 point)
5th Sep 2014 10:11am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6051 |
^^^^ +1
5th Sep 2014 10:20am |
Ring spanners are 12 point,someone go looksy,I too also can't remember,other than 1 was tight. Pov.spec,ftw. 2006, 110,TD5.
5th Sep 2014 10:49am |
wrong !!! 13mm |
5th Sep 2014 10:56am |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Munch is correct, It is 13 mm ...
But 1/2" AF Bi-Hex [12 point] fits better Guns and Landrovers .... anything else is irrelevant. |
5th Sep 2014 11:05am |
Ahhhh. Yes it's the axel ends that are 14mm hex
Andy |
5th Sep 2014 11:17am |
So not so dumb then
Complete brake overhaul on the 50th coming up pipes callipers discs n pads and new bolts were needed |
5th Sep 2014 9:23pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1572 |
13mm you are thinking of the bolts that hold the discs to the hubs which are 14mm.
1st Oct 2014 11:00pm |
