![]() | Home > Technical > Brake Calliper multispline bolt size |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
14mm I'm sure
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
12 point socket
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328
Thanks all
| kevinf Member Since: 12 Apr 2011 Location: sheffield Posts: 55
never worked on a puma, but every tdi and td5 brake caliper bolt as been 13mm bi hex(12 point)
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6219
^^^^ +1
Ring spanners are 12 point,someone go looksy,I too also can't remember,other than 1 was
wrong !!! 13mm |
| Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507
Munch is correct, It is 13 mm ...
But 1/2" AF Bi-Hex [12 point] fits better |
Ahhhh. Yes it's the axel ends that are 14mm hex
Andy |
So not so dumb then
Complete brake overhaul on the 50th coming up pipes callipers discs n pads |
| NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681
13mm you are thinking of the bolts that hold the discs to the hubs which are 14mm.
| All times are GMT |
