![]() | Home > Technical > Brake Calliper multispline bolt size |
14mm I'm sure
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5460 ![]() ![]() |
12 point socket
Thanks all
kevinf Member Since: 12 Apr 2011 Location: sheffield Posts: 55 ![]() ![]() |
never worked on a puma, but every tdi and td5 brake caliper bolt as been 13mm bi hex(12 point)
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6051 ![]() ![]() ![]() |
^^^^ +1
Ring spanners are 12 point,someone go looksy,I too also can't remember,other than 1 was
wrong !!! 13mm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Munch is correct, It is 13 mm ...
But 1/2" AF Bi-Hex [12 point] fits better ![]() |
Ahhhh. Yes it's the axel ends that are 14mm hex
![]() ![]() Andy |
So not so dumb then
![]() Complete brake overhaul on the 50th coming up pipes callipers discs n pads ![]() |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1572 ![]() ![]() ![]() |
13mm you are thinking of the bolts that hold the discs to the hubs which are 14mm.
