|  | Home > Technical > Brake Calliper multispline bolt size |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558    | 14mm I'm sure | ||
|  4th Sep 2014 8:59pm |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059    |  14 mm | ||
|  4th Sep 2014 10:19pm |
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055  | 12 point socket   Pov.spec,ftw. 2006, 110,TD5. | ||
|  4th Sep 2014 10:36pm |
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328    | Thanks all    for some dumb reason I had 1/2 inch in my head    | ||
|  5th Sep 2014 3:12am |
| kevinf Member Since: 12 Apr 2011 Location: sheffield Posts: 55    | never worked on a puma, but every tdi and td5 brake caliper bolt as been 13mm bi hex(12 point) | ||
|  5th Sep 2014 9:11am |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6219      | ^^^^ +1 | ||
|  5th Sep 2014 9:20am |
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055  | Ring spanners are 12 point,someone go looksy,I too also can't remember,other than 1 was    tight. Pov.spec,ftw. 2006, 110,TD5. | ||
|  5th Sep 2014 9:49am |
 wrong !!! 13mm | ||
|  5th Sep 2014 9:56am |
| Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507      | Munch is correct, It is 13 mm ...
 But 1/2" AF Bi-Hex [12 point] fits better  Guns and Landrovers .... anything else is irrelevant. | ||
|  5th Sep 2014 10:05am |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059    | Ahhhh. Yes it's the axel ends that are 14mm hex       Andy | ||
|  5th Sep 2014 10:17am |
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328    | So not so dumb then     Complete brake overhaul on the 50th coming up pipes callipers discs n pads  and new bolts were needed | ||
|  5th Sep 2014 8:23pm |
| NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681      | 13mm you are thinking of the bolts that hold the discs to the hubs which are 14mm. | ||
|  1st Oct 2014 10:00pm |
| Posting Rules
