Home > In Car Electronics > The definitive Defender ICE thread
Page 72 of 72 <123 ... 707172
For reference the Puma tweeters are 1”, that might be helpful info to have.
As there are 3/4” tweets as well, which are too small.
I have Kicker KS Series 1” on mine, on a dedicated Amp.
They have a fitting kit with them and a securing ring etc for behind, they are very loud and crisp if needed. Mr. Green ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1073508 16th Aug 2025 6:05pm
Mago
Germany
Good point about the 1" and 3/4", I'll keep that in mind. Thanks Smile
Very Happy Defender 90 TD5
Defender 110 Puma 2.4
Post #1073544 17th Aug 2025 5:04pm
Thumbs Up No worries, it can be a real pain when the wrong size can accidentally be bought. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1073560 17th Aug 2025 10:25pm
Mago
Germany
Hi,
Unfortunately, I still haven't received a response from any of the stores... Apparently, the speakers I originally had in mind are no longer available.
Someone recommended these as an alternative:
https://www.focal.com/de/produkte/isu-130
Some datasheets:
https://media.focal-naim.com/dam/tweeter-t...twu1-5.pdf
https://media.focal-naim.com/dam/isu-130/f...130_en.pdf
Does anyone have experience with them in a Defender?
The feedback from a German dealer is very positive, although all of them are in other vehicles (some say they expected a bit more bass).
Thanks and regards
Post #1073999 24th Aug 2025 10:29am
Unfortunately 10cm and 13cm do have their limitations with bass really, 160’s are better at least midrange, but Defenders have their fitting limitations, then there is engine noise etc. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1074057 25th Aug 2025 8:18pm
Mago
Germany
Okay, thanks for the assessment Smile
I read more tests and comparisons of speakers, their crystal-clear sound, etc. – and then I thought to myself: Honestly, this is a Defender, not a Bentley. There's no point in exaggerating it; the car itself isn't exactly quiet...
I'll give the ones mentioned above a try and report back.
Thanks and regards
Post #1074116 26th Aug 2025 9:02pm
Good luck. The brand is a very good one. Thumbs Up
Yes, Defender background noise is very influential.
To be honest sound proofing / dampening is an upgrade in itself also, a reduction in background noise just by 3dB is a real benefit to SQ in itself.
Very Happy ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1074117 26th Aug 2025 9:15pm
Mago
Germany
hHehe, thanks Wink
That's right, the sound proofing / dampening effect is impressive.
My roof is still missing, but otherwise, everything's done. I didn't expect a TD5 to be so quiet...
Regards
Post #1074173 27th Aug 2025 8:01pm
Mago
Germany
Thanks and regards
Very Happy
Hi everyone,
here we go - Thanks again for the tips.
I've now installed the Focal ISU 130, along with the Continental radio TRDW312UB-OR.
Please note that the speakers are delivered without grilles. The originals are 10cm, the ISU 130 is 13cm, so you'll need matching grilles.
The speakers fit well in the TD5; I used the new grille as a template and enlarged the hole accordingly with a jigsaw. That was unexpectedly easy. The tweeter cables are long enough to connect them to the speakers; a crossover is already integrated. I replaced the cables from the speaker to the radio, just in case.
The sound is nice and clear, much better than the original. As mentioned, the bass is okish with the 13cm speakers; you shouldn't expect (too) much here. Maybe a small subwoofer will be added later. If anyone has a good tip... Whistle
I think for a lean setup with a manageable investment, the ISU 130 are a good option.
Thanks again and greetings,
Post #1077790 17th Oct 2025 8:40pm
“Maybe a small subwoofer will be added later. If anyone has a good tip... Whistle”
I was waiting for that. Rolling with laughter Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1077798 17th Oct 2025 9:51pm
Mago
Germany
Hehehe ;D
Let's see what options there are for integrating a small and elegant subwoofer.
If anyone has a tip or recommendation... Whistle
I noticed that the bezel of the radio (FHF000070PMA) is quite loose and is only held in place by a single clip on each side, EYC106690.
The parts catalog lists the Wire Trim Retention (FBT000020), but I don't have them anymore. Thanks, previous owner.
Are they (also) there to secure the top and bottom panel? Then I'd retrofit them...
Thanks and greetings,
Post #1077854 18th Oct 2025 7:58pm
HardCharger
Hi All!
Was dreaming of a double DIN set up after being able to drive an office vehicle with Apple CarPlay and Android that came as standard.
Unfortunately, all my resources went into rebuilding my pride and joy. Thing being the case, I'm now just looking to replace my long in the tooth single DIN Alpine unit. Considerations are, works with bluetooth, supports hand free calling, and has green back lighting to match the rest of the dash. Eventually planning to pair with Focal front, tweeters, and rear speakers. Not really keep on a subwoofer though.
Suggestions on head units and how to get the most of this planned set up is much appreciated.
Also planning to do heat and sound insulation on the truck so this should help appreciate the outcome. No Better Friend, No Worse Enemy
Post #1077925 20th Oct 2025 8:33am
