Page 1389 of 1393 <123 ... 138813891390 139113921393>
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Removed the full beam switch to clean contacts to get my headlights working again and then change a headlight bulb that was also out.
Post #1069404 10th Jun 2025 10:34am
Jabberwocky
Luxembourg
Fitted an alive tuning ultimate Intercooler, not a difficult job just a bit fiddly especially as I have air con. New pipes as well. Had to fit a spacer to the fixing at the bottom of the air con condenser just to give me enough room for the thicker Intercooler. Slightly cramped with it having the flat front with aircon, I think I’ll have a bit of a re work of it, move the condenser forward a bit and fit the longer nose.
Will go for a drive tomorrow to see what if any difference it makes.
Post #1069441 10th Jun 2025 6:11pm
DG123
That was harder than I anticipated Rolling Eyes
 2012 110 XS SW Orkney Grey
2003 D2 Td5 Black [SOLD]
Post #1069535 11th Jun 2025 6:52pm
Screbble
Yes but just savour that feeling of satisfaction…
…until you try and get the bushes out…
Post #1069536 11th Jun 2025 6:57pm
Looking forward to the update. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1069541 11th Jun 2025 8:24pm
excossack
Replaced rear prop shaft - the old prop shaft had a little bit of play at the diff end UJ but the UJ felt like it had a flat spot when wiggling the UJ
TC end UJ felt better but not 100%
I did note the new prop only had one balance weight but the old one had about 3 of them
Replaced front diff oil after 10k for some fresh stuff. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1069562 12th Jun 2025 9:46am
revd
Barked my shins once to often. Removed the adjustable height tow hitch from my 110, nothing to tow at present (and only an evenings work to put it back) I was surprised how heavy it was. Will fit a couple of Jate rings for recovery jobs.
Post #1069566 12th Jun 2025 10:14am
excossack
Went to Ty Croes race circuit for radio cover for a rally that was running at the circuit
Discovered my clutch fluid had gone (again) Scrounged some more and topped it up
Nanocom thinks I was overheating on the drive home and coolant temp got to around 98c at times.
Sad 1999 Defender TD5 110
Regards
John M0VAZ
Post #1069779 16th Jun 2025 7:28am
excossack
Yesterday:
Drained and replaced gearbox oil
Drained and replaced transfer case oil.
Normally I use a 1 litre oil bottle with a tube and squeeze the oil into the each box. This time I purchased a 500ml syringe and used this to 'inject' the oil into each box.
Made life a bit easier. I think a 1000ml one would make life easier/quicker
Today.
Replaced the knackered clutch slave cylinder with a new one - now hopefully I have a non-leaking slave cylinder. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1070066 20th Jun 2025 3:59pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
Having fitted my solar panel the other week only to discover that my 60Ah AGM leisure battery (that probably wasn't really) was dead, recharging with sunlight to 13.6v or so by day and dropping to 10.02v or thereabouts every night new parts arrived so.......
Today the 60Ah battery and VSR came out and in went a Sterling Power DC-DC charger (with trickle back function) and a 100Ah LiFePo4 battery currently being charged up with solar and when the new fuses arrive tomorrow will be connected to the Sterling DC-DC so that it can charge when the Alternator is running but also trickle charge the main battery when the solar is running well and has more to offer than the LiFePo4 needs.
Now on to prepping the new Galvanised rear door for painting with a view to getting that on over the weekend. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #1070070 20th Jun 2025 5:22pm
300TDi CSW Phil
Well the bonnet was in a real state of lacquer wear so that has gone Raptor black as has the new back door on the outside.
The inside will go Raptor black tomorrow and then hopefully on tomorrow evening.
M0XQS
Post #1070113 21st Jun 2025 6:34pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
Drove the Stelvio Pass, Italy (not actually today mind, during a road trip over the last couple of weeks!)
 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #1070188 23rd Jun 2025 4:06pm
db950
Double post! 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #1070189 23rd Jun 2025 4:06pm
MussEd
Scotland 2013 Defender 110 Puma 2.2 USW Baltic Blue
Minor rush of blood saw me eventually tackle the radius arm bushes. Usual bolt related drama but got them off. That’s when the fun began. Absolute epic and all
I have to show is one old bush out and a car lying in bits. Lovely way to spend a day off.
Post #1070253 24th Jun 2025 5:30pm
Changed clutch fluid today ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1070256 24th Jun 2025 5:52pm
