Page 1390 of 1394 <123 ... 138913901391 139213931394>
L110CDL
db950 wrote:
Drove the Stelvio Pass, Italy (not actually today mind, during a road trip over the last couple of weeks!)
Cracking pic there db950 Very Happy Very Happy Clayton.
Keeper.
Post #1070318 25th Jun 2025 8:41pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
Well, best laid plans.....
The weekend came and went but today after 2 nights shifts the new back door went on with a bit of fettling.
Just four more to go and a colour change, I will start a separate thread on that when I get going. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #1070324 25th Jun 2025 9:29pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
Thanks but unfortunately I can’t take the credit!!
It was taken by a pro photographer who sits on one of the corners Very Happy 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #1070326 25th Jun 2025 9:39pm
L110CDL
Very Happy Thumbs Up Clayton.
Keeper.
Post #1070329 25th Jun 2025 9:48pm
300TDi CSW Phil
Not in but for...
Went to see the nice people at DDS Metal Services in Coventry to pick up most of the new doors.
Had some thoroughly interesting conversations with them and there was a Dutch registered Series 1 Station Wagon in the car park to ogle. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #1070378 26th Jun 2025 6:11pm
TamarBlue11
United Kingdom 2011 Defender 90 Puma 2.4 HT Tamar Blue
Fitted toughsystem drawers a while back and now a tote for extra storage out the way. Tote can just be unclipped which is handy when im taking a few tools in and out and draws are attached using custom brackets on existing factory holes.
Post #1070433 27th Jun 2025 3:41pm
MussEd
Scotland 2013 Defender 110 Puma 2.2 USW Baltic Blue
That looks great in there. Something else for mine I didn’t know I needed or wanted!
Post #1070445 27th Jun 2025 7:43pm
TamarBlue11
Thanks thought someone else might find it useful. It only overhangs the wing abit and gives some useful extra storage. Makes tools, recovery gear etc easy to grab especially if you have lots of stuff in the back like I do alot.
Post #1070451 27th Jun 2025 10:21pm
ChrisDefender
After jet washing the life out of the chassis last week and leaving it to dry, I took advantage of the hot weather to Lanoguard it ready for another year. It was done last Autumn and still looked great underneath.
Post #1070517 28th Jun 2025 10:19pm
Screbble
Changed engine oil and filters, fuel filter, and oil in diffs, gearbox, and transfer box. Greased all props and ball joints whilst under there.
A element of the placebo effect is kicking in…
Post #1070525 29th Jun 2025 7:55am
rustandoil
Tightened the contacts in the main relay and fuel pump relay bases.... They were very slack!
Applied Captain Tolleys to the windscreen / bulkhead seal
Post #1070526 29th Jun 2025 8:12am
excossack
A tip run and checked clutch fluid after swapping the slave. Looking good, fluid level has not dropped.
However, I did spot some coolant had dribble passed the coolant tank cap:-(
New cap on order. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1070559 29th Jun 2025 5:21pm
Andyslandytd5
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Took my 110 to Simply Landrover at Beaulieu motor museum and did the forest drive. I’ve been going for the last 5 years. The past 2 years have be been in my Puma 2.2 UXS. I skipped the off road course last year as the Drivetrain was full of slack. But since last year I’ve fitted one piece half shafts and it went into the garage for a LOF Powerade clutch and extreme spec output shaft so now has virtually no slack.
I made good use on of the tilt off-road function on the Stinger Heigh10. Was fun seeing how far we were tilting working our way around the course. We had 21degree to the side and 18degree down hill at different points of the course
Very impressed at how easy it was compared to my TD5 I had before. I only needed low range for 1 part of it as 1st is pretty low already
 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
2004 TD5 90 XS Station Wagon - 2019-2024
2003 TD5 90 G4 LE - 2009-2010
1990 Ninety 6.2 V8 Station Wagon - 2006-2009
Post #1071085 9th Jul 2025 1:36pm
tobias6
United Kingdom 2010 Defender 90 Puma 2.4 HT Tamar Blue
Brought home a new project!
 2010 90 Hardtop
1991 RR Vogue SE
Post #1071116 9th Jul 2025 3:56pm
L110CDL
Very nice Very Happy
what are the plans for the project ? Clayton.
Keeper.
Post #1071256 11th Jul 2025 8:32pm
