![]() | Home > Puma (Tdci) > wabco ABS |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 529 ![]() ![]() ![]() |
does it matter if you have a 2.2 or 2.4 tdci, is wabco in both
neon1991 Member Since: 26 Mar 2018 Location: Colchester Posts: 101 ![]() ![]() ![]() |
yes 2.2 is a later abs unit and not interchangeable if i remember rightly.
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2360 ![]() ![]() |
You are correct Neon1991. The 2.2 Puma has a Bosch ABS unit, not a Wabco .
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 588 ![]() ![]() ![]() |
Bosch or no ABS - on the early ones 2012/2013 you may still opt for a non-ABS spec
