![]() | Home > Puma (Tdci) > wabco ABS |
Swine&Small Member Since: 20 Mar 2017 Location: Norfolk Posts: 1223 ![]() ![]() |
Ouch !
![]() 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10385 ![]() ![]() |
top tip !! QRZ 2e0vpf
Craig-C Member Since: 25 Aug 2017 Location: Staffs Posts: 40 ![]() ![]() ![]() |
Just done the same job myself on my TD5. Worked a treat. My motor was also full of rust.
It is difficult to access but can be done on a TD5 by removing the inlet grill and ducting, wheel arch and loosening the brake pedal box. My Puma is a none ABS spec. ![]() Maybe the cost is just due to availability. FFRR TDV8 sold PUMA 90 :0[==]0: 90 TD5 CSW XS MX5 (NC) BMW 320 BMW 1200 GS Adventure SUZUKI HAYABUSA |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 941 ![]() ![]() ![]() |
As above, purely down to availability, all discovery 2s came with abs/traction control and were sold in their thousands, plus lots being scrapped due to chassis rot which is a shame really.
Useful to know though as my td5 has abs ![]() |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 342 ![]() ![]() ![]() |
Do you know if this works? Have you tested it with individual wheels with lost traction? It concerns me that not matching could cause the electronics of the ABS to release the wrong brake. |
neon1991 Member Since: 26 Mar 2018 Location: Colchester Posts: 101 ![]() ![]() ![]() |
yes, abs and TC work on the correct wheels. managed to get it cross axled on a local lane near me for a bit of a play.
Wabco only have one part number for these pumps. Landrover just plumbed them differently for the disco. New pump arrived yesterday so have a bit of a dilemma. fit it or keep it as a good spare... |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17911 ![]() ![]() ![]() |
I imagine that the ECU simply tells the modulator which brake line to pulse or release, and the mapping of wheel to output is in the ECU. If the ECU says modulate line 1, the modulator with do just that.
It's a handy tip to know that these are interchangeable*. ![]() * But I am still glad I don't have ABS/TC on my Defender, it would just be one more thing to go wrong. |
youre not wrong Lonewolf! It's not a fun job getting that lump out of the tiny little hole they found to put it in
andycowman Member Since: 22 Jan 2025 Location: devon Posts: 13 ![]() ![]() ![]() |
Bringing this thread back to say thank you for the tip!!
Mines in for a new gearbox and its MOT and then the lights came on and the pump is apparenlty dead and its now north of 3k just for the pump!!!! Off to ebay for a disco part.... |
welcome!
Bl**dy landrovers 🤣 might take the wing off as apparently the booster is leaking as well. Awesome.....
ooo hang on got confused, mine is a 2006 td5 defender. I assume the brakes are the same though? |
andyped Member Since: 11 Apr 2025 Location: Staffs Posts: 3 ![]() ![]() ![]() |
Hi neon1991, I'm facing the same issue with my 2007 Puma 90 and I can't source LR055940 anywhere at a sensible price. I wondered if the Disco 2 hack is still a valid option long term? Cheers |
just seen your post on the other thread. yes, best way to go in my opinion. I bought a disco 2 unit on the off chance that it would work. you just have to ignore the port labels and just connect the pipes how they were connected on your original unit.
That's very helpful, thanks a lot!
