![]() | Home > Puma (Tdci) > wabco ABS |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 551 ![]() ![]() ![]() |
does it matter if you have a 2.2 or 2.4 tdci, is wabco in both
neon1991 Member Since: 26 Mar 2018 Location: Colchester Posts: 101 ![]() ![]() ![]() |
yes 2.2 is a later abs unit and not interchangeable if i remember rightly.
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2519 ![]() ![]() |
You are correct Neon1991. The 2.2 Puma has a Bosch ABS unit, not a Wabco .
Julie Member Since: 07 Oct 2017 Location: La Réunion, Madagascar Posts: 589 ![]() ![]() ![]() |
Bosch or no ABS - on the early ones 2012/2013 you may still opt for a non-ABS spec
Worth giving these guys a call https://www.ebay.co.uk/itm/394307500843?_s...R4zJ_YeHZg
Superhigh2 Member Since: 23 Jul 2025 Location: London Posts: 3 ![]() ![]() ![]() |
Thanks so much Ianh, unfortunately I’ve tried ECU and the unit is not able to be repaired.
iriddell Member Since: 26 Jul 2025 Location: Toronto Posts: 1 ![]() ![]() ![]() |
Hey all! First time posting here ![]() I have a 2008 Defender 2.4 with an potentially pooched Wabco ABS Module. I have found a scrapped 2004 Discovery 2 in my area and hoping the switcharoo outlined in this thread will work on my truck too? By all accounts, it appears to be a compatible part. Nonetheless, im going to pull all the parts from the donor Disco2 and hopefully this works on my Wabco unit. Thanks so much in advance and happy to be joining the site ![]() |
