Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 47 of 111 <123 ... 464748 ... 109110111>
pjeski
United States
What do you guys use to compare ccfs?
I use a program called beyond compare by scooter software. I have it for comparing source code, but it compares a lot of things very well. Not affiliated with scooter, but really like the app.
Post #1005833 29th Aug 2023 9:50pm
forzahog
United States 2016 Defender 110 Other Works V8 Auto Fuji White
I use visual studio code with a diff plugin, excel tables sometimes, and even a sql db so I can use query language to do analysis. I'm one of the guys trying to figure out ACC, so I've used many tools to pull my hair out. Very Happy Thinking of using an AI tool if I can find one that can handle that sort of thing.
Cheers,
Kyle 20MY Defender 110 Fuji White
Post #1005834 29th Aug 2023 10:01pm
holtenc
United States
VS code. The built-in compare function worked really well for my needs.
Post #1005836 29th Aug 2023 10:05pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
On a Mac I use a programme called Kaleidoscope, you can lay 2 or however many ccf files together and it highlights the differences shown by the blue lines. (I have blurred some personal details on the image) Thumbs Up
 Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1005847 29th Aug 2023 11:39pm
matt4x4
Germany
Notepad++ with the Compare Plugin
Post #1005868 30th Aug 2023 9:09am
NoWayMe
Canada
pjeski wrote:
It's fixed.
Thumbs Up thanks for the head’s up! Ran the updater and sure enough so far 2 of my 5 changes worked on first startup. Will let the others sit overnight and check again.
Post #1005973 31st Aug 2023 5:08am
ODPA
United States
Glad to see you are all getting it sorted and working.
Post #1006119 1st Sep 2023 3:23am
NoWayMe
Canada
Okay so I got 007 screen, seatbelt remainder mute, auto start/stop remember and blinker/headlight combo to all work, but having trouble with dynamic mode. Am I doing something wrong? Or missing something? It’s been 1.5 days, numerous engine starts, 4-5 pivi resets …
I get the dynamic mode option screen but I can not see or select the dynamic mode icon with the rotary:
Even though the icon shows up on my dash screen when I move the rotary (just can not move it beyond the ECO mode icon):
I double checked that all files were correct as listed below:
Any insight? Did anyone else see the same results? Do I just need to wait longer for it to take effect?
Thanks for any info
Post #1006123 1st Sep 2023 6:34am
DefenderMidlands
Might also need
MultiCAN - 682 DynamicLiteMode.  Set to “Available for Selection Without Timeout”
My 562 is set to without timeout but not sure what different with or without makes
Post #1006124 1st Sep 2023 6:40am
mmbanf
Italy
hello,
try not to change the multican 777, leave the default setting.
initially it was not changed 777, the dynamic mode icon appeared on the touch screen and clicked on the screen.
double check that all this is modified.
if it doesn't work, post your total ccf sure we can compare it.
Marco
Post #1006125 1st Sep 2023 7:30am
MickD
United States
This is what I had changed when it was working for me.
EUCD - 245 Dynamic 1 set to “Dynamic 1 Content with Configurable Dynamic Mode Screen”
MultiCAN - 562 DynamicProgMode. Set to “Available for Selection Without Timeout”
MultiCAN - 605 ConfigDynamicMode. Set to “Fitted”
MultiCAN - 777 Ter Dyn Select In FCPB. Set to “rotary used for selection within touch screen”
Post #1006164 1st Sep 2023 1:40pm
Hairy Dan
Thanks for any info
Try running this command on your IID tool
Menu>Service Test>IDMA>Allow Central Configuration Data Learning
and see if that allows selection. Cheers Ian
Kielder 4x4 Safari
Post #1006170 1st Sep 2023 3:56pm
pjeski
United States
I did not set MultiCAN - 682 DynamicLiteMode. Set to “Available for Selection Without Timeout” , and mine seems to work fine WRT selecting past eco to dynamic. What do you get with DynamicLiteMode?
Also, I’m just in the habit of resetting the PIVI twice after each change that affects the HMI.
Post #1006275 2nd Sep 2023 8:51pm
pjeski
United States
I set MultiCAN-740 Drive Away Door Lock to Disabled, and that worked, if anyone is interested in that.
I tried MultiCAN-514 StopStartInhibitIcon to Stop Start Inhibited Icon disabled (Non-CFSS), hoping to get the icon off the cluster while my auto stop start is inhibited, but that did something other than I wanted if it did anything.
Post #1006276 2nd Sep 2023 8:59pm
aajr
United States
I wonder if you set this to enabled it makes it go away? The way it is written, it seems to me that enabled means it is inhibited.
Post #1006294 3rd Sep 2023 2:13am
