Home > Technical > dipstick broken off!!?
Page 2 of 3 <123>
ericvv
Dealer said that they already unscrewed the dipstick tube to see if the broken off part was stuck in there, but apparently not. Guess most likely it sits somewhere at the bottom of the sump. New sump and pasta are on order for Tuesday install.
When you do a search for broken dipstick on here, you will read several comments that the intake pipe/pump has a gauze fitted, so little chance the piece could be sucked into the engine, let alone pass the oil filter as a first step.
Will discuss at dealer Monday, then get the new sump installed Tuesday.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #649046 8th Sep 2017 7:04pm
zsd-puma
Quote:
I'm not sure about the puma but most oil pickup pipes have a strainer fitted, if this can be confirmed then I would leave it.
I'm yet to see any engine that doesn't have one. Possibly if you go back to the 1940's or earlier you might find one without a strainer of some kind.
Quote:
Hmmmmm..... looks like mine is Special edition. Might see what I can sell it for on ebay
Have you had it from new? It's possible someone lost the original and shoved something from another vehicle in there.
I assume you've pulled it out? As the tops of all of them are plastic for about the first 6 inches.
Post #649067 8th Sep 2017 9:34pm
Unfortunately. Glyn who made that comment hasn't been on here for nearly four years. Darren
Post #649075 8th Sep 2017 10:24pm
ericvv
So this morning the new sump arrived at my dealer (sorry, retailer) Rolling Eyes Laughing
The just fresh oil was drained again, old sump taken off, and yes, the broken off dipstick tip was in there. No way to use a magnet to draw it to the drainage hole as the dipstick tip is aluminium.
As dealer said that reinstalling a sump after removing is a guarantee for leaks as the sump by definition will have deformed, brand new sump installed again with fresh paste. No leaks. A new dipstick is on order, but this seems a factory order so will take about 10 days or so. They put in the correct amount of 6.8 liters of fresh oil again, and I just have to trust that the level is good as the dipstick for now is sitting in there without the measuring tip.
Those who have been here for a long time will remember that this is not a unique fault, quite a few threads exist about this very same problem. As I still checked the oil myself about three weeks ago before going on a holiday trip, and knowing about this problem I always remove the dipstick carefully, I did not notice anything at that moment that something was about the break off. Never had any real resistance when removing the dipstick, so seems a case of poor quality metal fatigue.
Conclusion is that Defender Tdci dipsticks are consumables, mine broke after 9 years, but quite a few do earlier than that. I guess from now on I am going to keep a spare in storage, and even if nothing appears wrong, replace it every 4 or 5 years now.
The good thing to know is that dealer confirmed nothing bad could have happened, from the sump to the oil filter there is a strainer, so no way that a broken off piece which is left to sit in the sump would ever be able to make it into the oil filter, let alone the engine.
Just have to dig out my Dinitrol cans in a few weeks from now, and when there indeed are zero leaks, Dinitrol the new sump.
A few pics below.
Eric
Post #649876 12th Sep 2017 5:15pm
flydive
Switzerland 2015 Defender 90 Puma 2.2 Heritage Edition SW Grasmere Green
Personally I would just have left it in.
Post #649879 12th Sep 2017 5:36pm
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
If that is what it looks like a Mazak die casting onto the end of a steel braid rope I am impressed that it lasted as long as nine years inside an engine.
The spring steel dipsticks were just too an expensive an idea for Ford Rolling Eyes 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #649885 12th Sep 2017 5:56pm
MK
Another taste of abysmal quality Puma 110" SW
Post #649900 12th Sep 2017 6:32pm
zsd-puma
How common occurance is it though? I mean that's two examples on here, out of how many Defender's with a Puma engine?
Post #649918 12th Sep 2017 7:40pm
HK07
England 2007 Defender 90 Puma 2.4 HT Cairns Blue
Hk07
I knew nothing of this as an issue, thanks for sharing Thumbs Up
I did however notice my dipstick was sticking 10-15% of the way up just after i bought it 9 years ago. I took the dipstick out and ground the top edge of the alloy measure at the bottom down to a very gentle taper. It now slips out with ease after one tug of the yellow hoop.
That statement needs to be taken in the context of this thread. Rolling with laughter 2007 90 Puma - Love it - Best car I have ever owned.
1989 Ninety 200tdi - Love it - Second best car I have ever owned.
1951 80" Series 1 - Love it - Third best car I have ever owned.
Post #649956 12th Sep 2017 9:06pm
ericvv
Post #649992 13th Sep 2017 2:34am
zsd-puma
So about 6 occurances in 10 years.
Post #650019 13th Sep 2017 9:41am
HeX
That would be seven then now Sad
Just made an oil change and of course AFTER having filled it with new oil the tip has broken off. I've now drained the oil and was about to take the sump down. But after reading that there is no danger the tip interfering with the engine (not even with the crankshaft?) I probably just fill the oil again and order a new dipstick.
Post #702167 21st Apr 2018 4:55pm
MK
If the tip is made of steel I would just put a magnet on the oil pan. Puma 110" SW
Post #702195 21st Apr 2018 7:05pm
ericvv
Post #702263 22nd Apr 2018 6:09am
ericvv wrote:
Out of interest how do you remove/insert the dipstick when checking?
Could it be that placing the end of the dipstick on the top of the tube and pushing as it goes down has over time caused this damage?
I tend to hold the wire several inches above the end with my right hand and bend the wire down with my left to ensure the first six inches or so go down the tube exactly square.
Post #702300 22nd Apr 2018 9:23am
Page 2 of 3 <123>
