Home > Puma (Tdci) > Clutch exchange |
bvandyk Member Since: 03 Sep 2012 Location: South Africa Posts: 49 |
I hope it sorts out the problem |
17th Oct 2012 10:54am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2597 |
After I got back from holidays, I sent a strongly-worded email to LRSA's complaints department asking them why they want to wait for my clutch to fail in the middle of nowhere before replacing it. They arranged for me to take it to LR Stellebosch for a proper assessment. Vehicle went in yesterday and they just called to say that after removing the clutch and visually inspecting it, they are indeed going to replace it. So looks like a Puma's clutch only lasts between 2000 - 3000km -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
11th Jan 2013 10:17am |
What exactly failed / went wrong? |
11th Jan 2013 10:24am |
Nothing yet, but it was starting to rattle, which means in a few thousand kms it would probably eventually fail. I insisted on having it replaced now because the landy is going out of warranty at the end of the month. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
11th Jan 2013 10:32am |
Pictures of the version 2 clutch that was replaced:
Click image to enlarge Click image to enlarge -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
17th Jan 2013 9:50am |
Would you mind putting a circle around the problem areas? I assume the warranty paid in full. Do you feel an improvement with the new clutch now? Can't believe that it didnt even last a year |
17th Jan 2013 10:02am |
The focus in the pics are the washer thingies - those little rectangular blocks are supposed to be filled with a washer IIRC. I have not gone to get the landy yet, will do so at lunch time and report back! -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
17th Jan 2013 10:09am |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 |
I've only saw this thread now!
I have never had a problem so far with my clutch, but I've noticed two of the symptoms described earlier is this post 1) Clutch Rattle during IDLE - which it seems is caues by a Thrust washer failure in the clutch plate assembly 2) Viabriation when ingenine is switched of since last October. The first symptom I notice it once a week maybe (and only knew that came from somewhere in the middle of the car, and just after reading this thread gave me a clue of what it could be), the second almost everyday... My Defender is a DC, 2010 model (AA793966) with now 38000km....Out of warranty by now (here in Portugal we have only two year warranty) Should I be considering getting a new clutch kit and wait till it breaks down or replace it as soon as I can? Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
17th Jan 2013 3:31pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
just had mine changed under arrenty at 16,500 mile on a late 2011 110.
would clunk and mke chnges very hrd when very wrm, not on normal usage. |
17th Jan 2013 6:06pm |
If it's out of warranty I would just leave it, and monitor it. If it gets very bad then I would go to the expense to replace. Except if you have money burning your pocket And don't use the dealers. You can get it replaced by an independant for a 3rd of the price |
18th Jan 2013 7:07am |
that's not the case... I'll keep monitoring...when it starts rattling everyday it will be a concern... Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
18th Jan 2013 10:27am |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 980 |
Mine's gone now. Still at least I'm not alone. Going in Thursday. Hope it holds for the LRO show trip.
Merlin |
6th Sep 2013 6:48pm |
Merlin, how many miles or kilometers? You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
6th Sep 2013 7:05pm |
60,000 miles. Is that good?
Merlin |
6th Sep 2013 9:14pm |
