Home > Puma (Tdci) > Light leveling motors constantly running
Page 2 of 2 <12
andy63
I had nothing better to do and couldn't stop thinking about this headlight levelling..
Cause I can't understand the control mechanism..😫
So best ignore the thoughts above..
I'm now thinking that the dash switch sends the motor controller a varying voltage signal and the motor controller then switches the motor one way or other and knows when to stop based on that voltage.. so it's likely the motor has a supply all the time and would be switched from within the motor control circut..
But I find it hard to believe both motor circuts would fail electrically at the same time..not impossible..just less likely
Hope you can get a resolution and post it.. and hope its not two new motors😫
Post #1069123 5th Jun 2025 8:23am
Johan_B
Sweden 2007 Defender 110 Puma 2.4 CSW Tonga Green
I actually came to the same conclusion after some late night googling yesterday. Permanent power supply to motors and they will stop when voltage is the same as what is coming from the switch.
I’ll take them out during the weekend and see if I can find something obvious. I’m thinking if the control rod is stuck for example, motor will try to move it but without luck. Therefore the signals will never agree.
I’ll report back whatever I find.
Post #1069201 6th Jun 2025 4:47pm
Johan_B
It’s been an eventful Saturday, curb side in Gothenburg. As I had the left headlight out, trying to figure out the hood latch studs, I took the levelling motor out.
First I unscrewed the adjustment screw a few turns and then I had look at the connector. It was green inside. Having nothing else at hand I sprayed some WD 40 into it and then plugged in and out a few times. Now it’s working as it should! Will the right one be as cooperative?
Post #1069267 7th Jun 2025 8:21pm
Siwynne
I read this a remembered mine were still not right. I’ll give them a clean at some point if parts of the 2.2 transit engine remain in the place they were meant to be- don’t explode-burst or fail.
Post #1069273 7th Jun 2025 10:06pm
Siwynne
Fixed this today. Simply adjusted the small screw in the end of the motor and they stopped. Re-adjusted the headlight level and all good. There must be some sort of switch inside the motor that wasn’t being activated. I had some paint done a while ago and these must have been messed with during reassembly
Post #1073090 10th Aug 2025 3:26pm
Page 2 of 2 <12
