![]() | Home > Puma (Tdci) > Light leveling motors constantly running |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 815 ![]() ![]() |
I had nothing better to do and couldn't stop thinking about this headlight levelling..
Cause I can't understand the control mechanism..😫 So best ignore the thoughts above.. I'm now thinking that the dash switch sends the motor controller a varying voltage signal and the motor controller then switches the motor one way or other and knows when to stop based on that voltage.. so it's likely the motor has a supply all the time and would be switched from within the motor control circut.. But I find it hard to believe both motor circuts would fail electrically at the same time..not impossible..just less likely Hope you can get a resolution and post it.. and hope its not two new motors😫 |
Johan_B Member Since: 20 Sep 2024 Location: Gothenburg Posts: 131 ![]() ![]() ![]() |
It’s been an eventful Saturday, curb side in Gothenburg. As I had the left headlight out, trying to figure out the hood latch studs, I took the levelling motor out.
First I unscrewed the adjustment screw a few turns and then I had look at the connector. It was green inside. Having nothing else at hand I sprayed some WD 40 into it and then plugged in and out a few times. Now it’s working as it should! Will the right one be as cooperative? |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 615 ![]() ![]() |
I read this a remembered mine were still not right. I’ll give them a clean at some point if parts of the 2.2 transit engine remain in the place they were meant to be- don’t explode-burst or fail.
Fixed this today. Simply adjusted the small screw in the end of the motor and they stopped. Re-adjusted the headlight level and all good. There must be some sort of switch inside the motor that wasn’t being activated. I had some paint done a while ago and these must have been messed with during reassembly
