Home > Puma (Tdci) > Starter motor and why it failed
spudfan
Ireland
The starter motor on the Puma began to make a funny noise on kicking so I knew attention was due. Within two weeks it stopped working but did make a very good bag of nails sound. I could not believe how quickly it collapsed. I was actually awaiting a call back from the garage about getting the starter motor seen too. The reason for this sudden catastrophic failure was due to the following.
In 2018 the Puma went into a garage who I trusted and who had served me well. The clutch was changed so I can only surmise that the starter motor was removed during this process and refitted afterwards. Here lies the problem.
If you look at the diagram included in the link, you will see that there are two small dowels, TYT500020, that go on the bolts fixing the starter motor to the engine. These were not fitted when the starter motor was refitted. So over time the starter motor worked loose. The mechanic who is working on it now told me that the starter motor was loose to hand when he went to work on it. Anyway once the starter motor began making the funny noise I stopped using the Puma except locally. It is just as well as it failed completely when it was parked nose in to a wall in our yard.
https://www.advancedfactors.co.uk/starter-...1181-c.asp 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #952476 13th May 2022 1:51pm
X4SKP
Hello supdfan
I went back and checked my Install...
LR OEM Starter Motor LR25840
NYR500010
You can just make out the stepped (counterbored) Holes to Locate onto 'Dowels' TYT500020
My memory is that these 'Dowels' remained In Place on the Bell Housing aiding Location before
drawing in Starter Motor on Assembly
I have No Loose photo's of them... SKIP
Post #952483 13th May 2022 2:51pm
It's a little hard to understand why anyone would remove the starter motor while changing a clutch, it's totally unnecessary and is both awkward and time-consuming.
Post #952484 13th May 2022 2:53pm
spudfan
Ireland
When my starter motor was removed the mechanic said the dowels were not in place. Thank you for the photos and info. Thumbs Up 1982 88" 2.25 diesel
Post #952485 13th May 2022 2:54pm
spudfan
Ireland
That's the only reason the mechanic can think of as to why the dowels are not in place. I have had the vehicle from new. 1982 88" 2.25 diesel
Post #952486 13th May 2022 2:57pm
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
either that or it left the factory without them?
Post #952491 13th May 2022 5:00pm
