Home > Technical > Central locking module |
s55shh Member Since: 30 Dec 2019 Location: staffs Posts: 186 |
if you have the new type fobs, then you will have the later spec black ALM module (part number starts with a DH not a CH) look behind drivers speaker. These can be programmed to do central locking but finding someone competent can be interesting.
9th Feb 2021 12:46pm |
kinchjet Member Since: 02 Oct 2012 Location: doncaster Posts: 6 |
Ive confirmed the Part number begins with DH12 -15K
do i have to get the main dealer to code it for CL or can an independant do this ? |
21st Feb 2021 9:06pm |
AlexCW Member Since: 04 Mar 2020 Location: Staffordshire Posts: 66 |
My Puma is a 2013 with the key with the chrome strip which I believe yours will be? I had a nightmare trying to get a key coded as no independents have the software (one mentioned Land Rover want £10 000 for the licence, not sure how true that is) and in the end, had to go to a main dealer as they're the only ones with the software to do anything with the later immobiliser (2013-2016).
Alex Alex 2013 2.2 TDCi Puma Hard Top https://www.defender2.net/forum/topic72473.html |
21st Feb 2021 10:13pm |
Thanks Alex]
yes i have the chrome strip keys .will talk to my dealer tomorrow KR Paul |
21st Feb 2021 10:35pm |
LRC4x4 in Congleton have the main dealer software to access the ALM modules.
22nd Feb 2021 10:50am |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 421 |
Blackbox claim the Nanocom to do this job. In this case, it seems to be just à few hundred bucks... |
22nd Feb 2021 7:16pm |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2260 |
Im not sure the nancom can access the my2015 onward alarm system........others might know better?
22nd Feb 2021 11:50pm |
Well, then - just look on their website
Otters won’t know better than they do |
23rd Feb 2021 9:07am |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 756 |
Thought there was an update recently that meant they could access the later model alarm system. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
23rd Feb 2021 11:08am |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 546 |
I think the ALM unit is part of the 1.36 beta Nanocom software, I'm not sure what it can do tho.
Cheers Will 2005 90 XS 1954 86'' Series 1 tilt |
23rd Feb 2021 1:23pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1841 |
See nanocom site, at bottom click on ALM section https://www.nanocom-diagnostics.com/produc...-24-22-kit
Reading the documents I’m no more enlightened as to whether you can enable central locking on the ALM module with the puma 2.4/ 2.2 software. They have a contacts page where you can highlight your specific requirements and they will be able to advise if the nanocom can do it, what version you will need and the steps to follow if it can. https://www.nanocom-diagnostics.com/contact If it can do what you want it may be cost effective to purchase via one of the group buys as it provides so many other benefits. Alternatively reach out to members on here that have one locally with the 2.4/2.2 puma software. |
23rd Feb 2021 1:41pm |
The website clearly states what the nancom will do regarding the alarm a d key fob settings for pre my2015 defenders....but it is a little hazy on the my2015 defenders.. .... If anybody on here has a My2015 defender and uses the nancom to access the alarm mode I would be very surprised but would purchase one the next day. |
23rd Feb 2021 2:30pm |
