Home > Technical > Air con condenser
Page 4 of 4 <1234
andre.prum
Luxembourg 2011 Defender 110 Puma 2.4 SW Fuji White
Thanks Darren for your advice.
Is there any way to check the valve without dismounting it ?
Post #915011 1st Aug 2021 2:32pm
Yes, the operating lever is on the outside of the valve and is connected to the heater control knob by a cable. Rotate the knob all the way to cold and then see if there's any travel left on the operating lever. If there is then the valve isn't being closed properly. You might be able to adjust the cable (can't remember what the end fitting is without looking) but some folks on here have even fitted springs to the lever to assist with closing the valve. Darren
Post #915087 1st Aug 2021 10:31pm
hank
Matt110 wrote:
Given the weather you've got there right now do you notice a performance improvement with the bigger condenser?
Difficult to compare as my air con hasn't been working for a couple of years! But it's certainly performing well now > 110 XS Double Cab
Post #915122 2nd Aug 2021 9:52am
andre.prum
thanks, just checked and the valve seems to be closing well. possibly it was just a little open when I drove on the highway. hope that closing it directly on the valve will avoid the hot air
Post #915128 2nd Aug 2021 10:38am
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Nice find on the condenser Hank! Seems to be some AC experts on this thread, so I'll put this out there. My condenser fan runs non stop. I have been unplugging it every fall to stop it from running through the winter. Had my local go through and check everything, no luck. Anyone have any thoughts on where to start? it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #918335 23rd Aug 2021 3:49pm
jmccoy55555
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Linked one looks sold out.
This one https://www.ebay.co.uk/itm/363440780259 looks the same....
Would anyone have the dimensions of the OEM one handy?
Post #932615 6th Dec 2021 2:23pm
Stanyx
Belgium 2013 Defender 110 Puma 2.2 DCPU Fuji White
Hi there, found 2 alternatives for the OE condensor unit, now priced at £700:
NRF Easy Fit 350489 Condensor, airconditioning
15,5mm, 15,5mm, 675mm
art: 350489
MAHLE ORIGINAL (LR025985)
16mm, 15,5mm, 655mm
art: AC 1084 000S
Hope this helps,
Stéphane
Post #1005494 26th Aug 2023 4:35pm
Trendkill110
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Barolo Black
Hello folks!
Does anyone have a link for the condensor Hank bought and fitted? None of the above links are working anymore.
Upgrading the intercooler next week so going to do this at the same time.
TIA 👍🏻
Post #1011942 20th Oct 2023 7:21pm
bankz5152
https://www.ebay.co.uk/itm/115768660522?mk...media=COPY
Same part number as the one I bought but might be worth a message to double check.fitment.
Post #1011945 20th Oct 2023 7:31pm
Page 4 of 4 <1234
