Home > Maintenance & Modifications > Dinitrol rustproofing treatment system
Page 2 of 2 <12
Sulisuli
im sure someone will be along shortly to assist us Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #790895 6th Sep 2019 2:09pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
I'd ask Bilt Hamber. They're very approachable.
Post #790902 6th Sep 2019 2:51pm
X4SKP
Sulisuli wrote:
Does anyone know if say you use Dinitrol as your first rot protection application then 3 or 4 years down the line you think perhaps BH is worth a try or other similar respected products can you overspray the Dinitrol after obviously giving it a full clean and allowing it to dry correctly or do the previously used products need to be totally removed?
Hi Sulisuli,
Both Bilt Hamber and Dinitrol are excellent products. I have used both.
I would say generally a product will stick to itself better than another.
Unless you strip back a chassis / bodywork to its core it is likely that however well cleaned previous treatments will remain.
For me Dinitrol on the Defender (factory finish) it applied really well and has lasted,
when needed to be 'refreshed' I will use the same.
I have seen Dinitrol applied over a 'riot' of previous coating, (on a MKII Jaguar) waxoyl, 'galvanised' paint, red oxide,
hammerite etc and it looked good, the body shop did use a degreasing spay and left the body in their oven overnight before protecting with Dinitrol, they said they had done this before (Austin Healey) and the Dinitrol had both taken well
and lasted, so from this I'd say Dinitrol would probably over finish previous coatings.
I've used Bilt Hamber on a Caravan Chassis, again really impressed, it was previous 'untreated' with only a painted
factory finish. SKIP
Post #790917 6th Sep 2019 5:01pm
Sulisuli
^ Thankyou for the detailed reply Thumbs Up I am a fan of Dinitrol and will be having it redone next year as it will be 3 years old since first professionally done. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #790941 6th Sep 2019 6:22pm
Swine&Small
3 years since my dinitrol was applied, so probably due for an inspection.
It was done by Chriss Kill who used to be a sponsor on here, does anyone know if he is still in business 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller
1966 Morris Convertible
2012 VW T5 Camper
Quod Abundat Non Obstat.
Post #797856 12th Oct 2019 4:43pm
JOW240725
CSK are very much still in business Thumbs Up James
Instagram @suffolk_rovers
Post #797864 12th Oct 2019 5:27pm
m3vert
Scotland 2011 Defender 110 2.5 TD PU Stornoway Grey
Someone asked about going over Dinitrol with other products, I do not know the answer to that. But I do know that Dinitrol can be used to go over other products as I have just had that done on my 110DCPU. I have a thread showing the work here: https://www.defender2.net/forum/post797926.html#797926
Post #797928 13th Oct 2019 9:39am
Page 2 of 2 <12
