![]() | Home > Maintenance & Modifications > Dinitrol rustproofing treatment system |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
im sure someone will be along shortly to assist us
![]() 2008 SVX 90 2000 XS TD5 90 |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
I'd ask Bilt Hamber. They're very approachable.
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304 ![]() ![]() ![]() |
Hi Sulisuli, Both Bilt Hamber and Dinitrol are excellent products. I have used both. I would say generally a product will stick to itself better than another. Unless you strip back a chassis / bodywork to its core it is likely that however well cleaned previous treatments will remain. For me Dinitrol on the Defender (factory finish) it applied really well and has lasted, when needed to be 'refreshed' I will use the same. I have seen Dinitrol applied over a 'riot' of previous coating, (on a MKII Jaguar) waxoyl, 'galvanised' paint, red oxide, hammerite etc and it looked good, the body shop did use a degreasing spay and left the body in their oven overnight before protecting with Dinitrol, they said they had done this before (Austin Healey) and the Dinitrol had both taken well and lasted, so from this I'd say Dinitrol would probably over finish previous coatings. I've used Bilt Hamber on a Caravan Chassis, again really impressed, it was previous 'untreated' with only a painted factory finish. SKIP https://www.defender2.net/forum/topic83242.html |
Swine&Small Member Since: 20 Mar 2017 Location: Norfolk Posts: 1223 ![]() ![]() |
3 years since my dinitrol was applied, so probably due for an inspection.
It was done by Chriss Kill who used to be a sponsor on here, does anyone know if he is still in business 1983 Series 3 Pick up in Marine Blue 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7939 ![]() ![]() ![]() |
CSK are very much still in business
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
m3vert Member Since: 15 Mar 2018 Location: Central Scotland Posts: 162 ![]() ![]() ![]() |
Someone asked about going over Dinitrol with other products, I do not know the answer to that. But I do know that Dinitrol can be used to go over other products as I have just had that done on my 110DCPU. I have a thread showing the work here: https://www.defender2.net/forum/post797926.html#797926
