Home > My Defender > hanks Double Cab
Page 13 of 22 <123 ... 121314 ... 202122>
hank
Bigger 14" SPAL AC fan fitted to condenser
 > 110 XS Double Cab
Post #914078 26th Jul 2021 12:09pm
Welshsurferdude
Wales
Ill be fitting the same once I find my new 110! 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #914088 26th Jul 2021 1:05pm
L110CDL
That looks much better to do the job properly Thumbs Up Clayton.
Keeper.
Post #914325 27th Jul 2021 9:26pm
hank
Missed your reply Clayton - thanks!
Made a start on the dogs seat for the drive down to Italy. Having the dog in the front frees up the rear seats for luggage which is essential since double cabs are crap for load space.
These front centre seats are not meant for Puma's and their mounts position the seat too far forward meaning it nudges the transfer box shifter into neutral so I cut the mounts off and welded in two lengths of 25mm square hollow section to the seat frame which pick up to the cubby box fixings.
I appreciate that this would fail an MOT and that the cubby fixings are not beef enough to mount a seat etc... But it's just somewhere for the dog to sit and will be swapped back to the cubby when I return home
Had to wait for the paint to dry but will fit the seat covers and put it in the Defender later
 > 110 XS Double Cab
Post #916346 10th Aug 2021 3:15pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
What a great idea, looking forward to seeing it fitted. How big is the dog? WARNING.
This post may contain sarcasm.
Post #916373 10th Aug 2021 5:06pm
hank
XS seat cover fitted and in the vehicle. Bit of a squeeze with the premium seats!! Dog is small/medium, around 16kg… Jack Russel mongrel cross
 > 110 XS Double Cab
Post #916377 10th Aug 2021 5:36pm
Co1
Very tidy install. Looks great.
Post #916384 10th Aug 2021 6:26pm
bankz5152
Looks good! You say that about the middle seat, but the standard front seats are held in place with 4 oversized m8 rivnuts. No different to the cubby box fixings..
Post #916401 10th Aug 2021 7:54pm
hank
Next job this evening was the panhard rod bushes. My steering had developed a notch between left and right turns as well as a general feeling of vagueness. You could see the rod eyes move with steering input!
Ordered a superpro full vehicle kit from Gwyn Lewis and did the panhard bush this evening… Notch is gone and steering is a lot more positive. Will get the other bushes on over the next week or two.
 > 110 XS Double Cab
Post #916403 10th Aug 2021 7:58pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Seat is looking good!
Will be interested to know how you get on with the super pro bushes. I’m torn on whether to go for super pro or genuine in the future.
Post #916405 10th Aug 2021 8:21pm
hank
Ahhh there we are then! I suppose it's the seat belt mounts that need strength in case of an accident. The seat acts in compression not tension! > 110 XS Double Cab
Post #916460 11th Aug 2021 10:52am
L110CDL
Good to see a middle seat in and it's looking good Thumbs Up Clayton.
Keeper.
Post #916630 12th Aug 2021 9:08pm
hank
Superpro bush kit now fitted to the vehicle complete with new suspension bolt kits front and rear. Feels slightly less wooly/a bit more positive to drive. The old bushes were the originals so probably due a refresh after 15 years/90k miles.
Also have a new set of injectors to go in so hopefully get them done one day this week at which point I think the old girl is all set for the drive to Italy > 110 XS Double Cab
Post #918500 24th Aug 2021 10:49am
hank
I had suspected for a little while that the injectors may have been misbehaving as the Defender seemed to be down on power. It didn't seem to have the same oomph that it once did, seemed to need more revs to make power/torque, losing speed on long motorway climbs and dire performance recently when towing a few tonne. Just didn't seem to go how I remembered or how you would expect the 'duratorq' to perform.
Ordered a set of reconditioned Denso DCRI107060 injectors from P F Jones (no affiliation) at £72 per piece https://www.pfjones.co.uk/ford-transit-2.2...0-pfj.html
Last week I made a start on fitting the new (reconditioned) injectors but a damaged rocker cover stopped play.
This time as well as cleaning up the injector seats with the seat cutter I also spent a fair bit of time cleaning up the injector counter bores in the head of every spot of carbon/gunk/fried oil using a brass wire brush/bottle cleaner as I was conscious of knocking any 'bits' down onto the injector seat when sliding the injectors home and introducing any weakness in the seal.
I was pleased with the result - spotlessly clean bright aluminium counter bore and seat ready to accept the new injectors.
Just when I was ready to reassemble I noticed the inner PCV 'baffle' in the rocker cover was cracked/broken so a replacement rocker cover was ordered (Ford part number 1516726)
New rocker cover arrived today so reassembly could continue. Below is a shot of the bright aluminium injector counter bore looking through the rocker cover seal
Four injectors slid straight home with a satisfying 'clunk' as they located on the seat in the head.
With brand new injector clamp brackets and stretch bolts torqued down (6Nm + 180deg), the fuel feeds, returns and connectors were refitted and the injector codes programmed using the BAS tool.
Fired up after a bit of a crank and OH MY GOD it's like a different vehicle! Comes on song around 1800 - 1900rpm like it should and goes like the clappers with no black smoke out of the exhaust. All I can think is that the old injectors must have been completely knackered. It also runs quieter, with the 'tick tick ticking' now gone and also no 'chuff' coming out of the oil filler on removal.
I wish had done this ages ago. It's a job I had been putting off after reading horror stories about £1000 - £2000 injector repair bills but at £288 it wasn't so bad at all. Look forward to towing something heavy and seeing how it performs
Old Injectors
New one (only got a photo of one)
And all back together
 > 110 XS Double Cab
Post #919405 31st Aug 2021 8:43pm
hank
I thought it was probably worth sticking a new fuel filter on to give the new injectors the best chance of longevity
Went for a genuine JLR one. Quite a bit of muck came out of the old one so looks as though it was worth a change
Simple five minute job.
1. Remove Cover
2. Fill the new filter to the brim with diesel
3. Unscrew the old filter
4. Screw the diesel filled new filter on. I did this quick to minimise any fuel loss from the system
5. Refit cover
Started back up on the button.
In other news I towed a couple of tonne of sand this week - effortless. So pleased I changed the injectors Thumbs Up
 > 110 XS Double Cab
Post #920096 5th Sep 2021 1:09pm
