Home > Puma (Tdci) > My first warning light, is this my welcome to ownership :)
Page 3 of 3 <123
Any tips for removing the plug? I've never needed to remove mine but seems a knack to it.
Remove the red bit back but mine still won't come off, maybe just a bit stuck? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #573953 28th Oct 2016 12:39pm
Cupboard
pull the red bit back then give it a wiggle.
Or if you do it a bit too violently, break the red bit off and then hold the plug in with a cable tie Rolling Eyes Laughing
The first few times I did it I just gave it a bit of a wiggle and it unplugged. Then got a bit blasé with it and the red bit disappeared. It's much easier to remove if all you have to to is un-hitch the cable tie!
Post #573957 28th Oct 2016 12:57pm
Stacey007
Hello
Thanks I'm not getting the engine light on the dashboard, just the beep from my guage saying pending error..
Is this bit easy to remove from car and is it the part circled I need to clean and they spray with WD40?
Thanks
Post #573967 28th Oct 2016 1:41pm
X4SKP
Hello Stacey007
Yes easy to remove, Air Filter Cover Off, Trox Screws removed, wiggle Sensor out... Thumbs Up
I only used WD40 on the connector NOT the Sensor as it is designed to remain dry.
Good Luck SKIP
Post #573973 28th Oct 2016 2:23pm
Page 3 of 3 <123
