![]() | Home > Puma (Tdci) > My first warning light, is this my welcome to ownership :) |
pull the red bit back then give it a wiggle.
Or if you do it a bit too violently, break the red bit off and then hold the plug in with a cable tie ![]() ![]() The first few times I did it I just gave it a bit of a wiggle and it unplugged. Then got a bit blasé with it and the red bit disappeared. It's much easier to remove if all you have to to is un-hitch the cable tie! |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3854 ![]() ![]() |
Hello
Thanks I'm not getting the engine light on the dashboard, just the beep from my guage saying pending error.. Is this bit easy to remove from car and is it the part circled I need to clean and they spray with WD40? Thanks ![]() Click image to enlarge |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello Stacey007
Yes easy to remove, Air Filter Cover Off, Trox Screws removed, wiggle Sensor out... ![]() I only used WD40 on the connector NOT the Sensor as it is designed to remain dry. Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
