![]() | Home > Technical > 110 vomiting diesel |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8494
If you are using a std sized pump in would suggest blocked breather. If a high speed out lorry pump then prob just what it will do.q Cheers
| Nevillerover Member Since: 14 Feb 2015 Location: Suffolk Posts: 224
My old ones with the slide up filter tube did that but the new ones without the filter tube don't.
I just learnt to hear the sound that signalled impeding trouser slosh and back off the pump accordingly to let it settle. I think you are better off have the tube pulled up if you have one. |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
what model year etc is 110 ?
| Honcho Member Since: 08 Mar 2014 Location: ^^^ Posts: 49
Its a 2002 TD5 110 DCPU
Filling at standard fuel pumps jst The first time it happened Nevillerover I got caught by the splash |
blocked or kinked breather pipe ?
maybe hold nozzle at different angle , sometimes if nozzle pointing upwards in the filler neck it blocks the breather outlet in the neck or the flow of diesel pushes down breather outlet causing blow back |
| All times are GMT |
