|  | Home > Technical > 110 vomiting diesel |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8491      | If you are using a std  sized pump in would suggest blocked breather. If a high speed out lorry pump then prob just what it will do.q Cheers
 James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop | ||
|  9th Apr 2015 5:30am |
| Nevillerover Member Since: 14 Feb 2015 Location: Suffolk Posts: 224      | My old ones with the slide up filter tube did that but the new ones without the filter tube don't.
 I just learnt to hear the sound that signalled impeding trouser slosh and back off the pump accordingly to let it settle. I think you are better off have the tube pulled up if you have one. | ||
|  9th Apr 2015 5:48am |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558    | what model year etc is 110 ? | ||
|  9th Apr 2015 8:13am |
| Honcho Member Since: 08 Mar 2014 Location: ^^^ Posts: 49    | Its a 2002 TD5 110 DCPU
 Filling at standard fuel pumps jst The first time it happened Nevillerover I got caught by the splash  I can fill it slowly but you know your self when you are in a hurry and you hop out in good cloths, thats when I will forget about it and end up wearing Eau De Diesel | ||
|  9th Apr 2015 8:37am |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558    | blocked or kinked breather pipe ?
 maybe hold nozzle at different angle , sometimes if nozzle pointing upwards in the filler neck it blocks the breather outlet in the neck or the flow of diesel pushes down breather outlet causing blow back | ||
|  9th Apr 2015 8:57am |
| Posting Rules
