![]() | Home > Technical > 110 vomiting diesel |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8341 ![]() ![]() ![]() |
If you are using a std sized pump in would suggest blocked breather. If a high speed out lorry pump then prob just what it will do.q Cheers
Nevillerover Member Since: 14 Feb 2015 Location: Suffolk Posts: 224 ![]() ![]() ![]() |
My old ones with the slide up filter tube did that but the new ones without the filter tube don't.
I just learnt to hear the sound that signalled impeding trouser slosh and back off the pump accordingly to let it settle. I think you are better off have the tube pulled up if you have one. |
what model year etc is 110 ?
Honcho Member Since: 09 Mar 2014 Location: ^^^ Posts: 49 ![]() ![]() |
Its a 2002 TD5 110 DCPU
Filling at standard fuel pumps jst The first time it happened Nevillerover I got caught by the splash ![]() |
blocked or kinked breather pipe ?
maybe hold nozzle at different angle , sometimes if nozzle pointing upwards in the filler neck it blocks the breather outlet in the neck or the flow of diesel pushes down breather outlet causing blow back |
