Home > Technical > 110 vomiting diesel
Honcho
Ireland
110 vomiting diesel
When I fill my 110 with diesel at the pumps, it fills a little and then vomits some of it back out at me. I take it there is some sort of air lock problem somewhere.
Has anyone had this problem with their defender?
Post #414894 8th Apr 2015 9:55pm
jst
If you are using a std sized pump in would suggest blocked breather. If a high speed out lorry pump then prob just what it will do.q Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #414935 9th Apr 2015 6:30am
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
My old ones with the slide up filter tube did that but the new ones without the filter tube don't.
I just learnt to hear the sound that signalled impeding trouser slosh and back off the pump accordingly to let it settle.
I think you are better off have the tube pulled up if you have one.
Post #414937 9th Apr 2015 6:48am
munch90
what model year etc is 110 ?
Post #414948 9th Apr 2015 9:13am
Honcho
Ireland
Its a 2002 TD5 110 DCPU
Filling at standard fuel pumps jst
The first time it happened Nevillerover I got caught by the splash Evil or Very Mad I can fill it slowly but you know your self when you are in a hurry and you hop out in good cloths, thats when I will forget about it and end up wearing Eau De Diesel
Post #414953 9th Apr 2015 9:37am
munch90
blocked or kinked breather pipe ?
maybe hold nozzle at different angle , sometimes if nozzle pointing upwards in the filler neck it blocks the breather outlet in the neck or the flow of diesel pushes down breather outlet causing blow back
Post #414958 9th Apr 2015 9:57am
