![]() | Home > Maintenance & Modifications > One door shuts....then another one opens :-) |
ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge ![]() |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 ![]() ![]() |
If it helps with your rear window winder, take it off and turn it down 90 degrees, should stop it coming open!
cool like 6 o'clock? how do i get to the bolt...
If the door can swing open to 90 degrees and the wind (or kid) catches it, it goes too far and the forward edge puts a crease in the pillar. Don't ask me how I know ![]() But shout it at them in German because life is also terrifying and confusing... |
Would that be a LR 'camel toe'...
Thats it! Theres a little clip behind the handle that you need to flick out slightly to release the handle. A thin flat screwdriver should do it. Sorry, thats possibly the worst description possible!! |
AlpenAndes Member Since: 20 May 2011 Location: Currently Chile Posts: 128 ![]() ![]() ![]() |
Rather like something 4 or 5 o'clock, to let mother earth keep the winder down and your window up. Apparently that got forgotten with electric windows. Behind the winder is a spring/splint, however you call that in English, which holds it on that axle, take it out and you can take the winder off. BR Oskar |
Thank you - I will never see it the same way again ![]() ![]() But shout it at them in German because life is also terrifying and confusing... |
Get ready to catch the clip though. A knackered narrow flat bladed screwdriver or strip of steel with the end of the bent at a right angle is handy to hook behind the loop end of the clip.
Another tip for someone to rehash and be considered an expert ![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
I tried repositioning them but it didn't help so I used a more "robust" approach:
![]() Click image to enlarge As I bought decent black elastic cord and hid the knot inside the hollow of the handle, it actually isn't that obvious ![]() Haha - just noticed ti-fat did the same :rolllaugh: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() But shout it at them in German because life is also terrifying and confusing... Last edited by ZeDefender on 27th Nov 2012 6:39pm. Edited 1 time in total |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20951 ![]() ![]() |
ZE - Dogs would love to chew that handle.
![]() ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Small children too - that's why I keep them behind this ![]() Click image to enlarge :twisted: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() But shout it at them in German because life is also terrifying and confusing... |
Where did you buy those brackets from please? Brilliant solution. I take it the bracket and arm are the kit to replace the original LR ones? |
As well as that Entreq solution (very elegant but 60 something quid) you can also just add a small extension (moves the pivot 26mm)
![]() Click image to enlarge Make them yourself or X-Eng will soon be doing them for around a tenner. Forgot to say, the Entreq brackets are just a straight swap - Brendan (Leeds) is our "family" distributor and gives good deals :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() But shout it at them in German because life is also terrifying and confusing... |
