![]() | Home > Maintenance & Modifications > One door shuts....then another one opens :-) |
| ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517
| JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758
If it helps with your rear window winder, take it off and turn it down 90 degrees, should stop it coming open!
cool like 6 o'clock? how do i get to the bolt...
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
If the door can swing open to 90 degrees and the wind (or kid) catches it, it goes too far and the forward edge puts a crease in the pillar. Don't ask me how I know But shout it at them in German because life is also terrifying and confusing... |
Would that be a LR 'camel toe'...
Thats it! Theres a little clip behind the handle that you need to flick out slightly to release the handle. A thin flat screwdriver should do it. Sorry, thats possibly the worst description possible!! |
| AlpenAndes Member Since: 20 May 2011 Location: Currently Chile Posts: 128
Rather like something 4 or 5 o'clock, to let mother earth keep the winder down and your window up. Apparently that got forgotten with electric windows. Behind the winder is a spring/splint, however you call that in English, which holds it on that axle, take it out and you can take the winder off. BR Oskar |
Thank you - I will never see it the same way again But shout it at them in German because life is also terrifying and confusing... |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
Get ready to catch the clip though. A knackered narrow flat bladed screwdriver or strip of steel with the end of the bent at a right angle is handy to hook behind the loop end of the clip.
Another tip for someone to rehash and be considered an expert Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
I tried repositioning them but it didn't help so I used a more "robust" approach:
Click image to enlarge As I bought decent black elastic cord and hid the knot inside the hollow of the handle, it actually isn't that obvious Haha - just noticed ti-fat did the same :rolllaugh: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated But shout it at them in German because life is also terrifying and confusing... Last edited by ZeDefender on 27th Nov 2012 6:39pm. Edited 1 time in total |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21029
ZE - Dogs would love to chew that handle.
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Small children too - that's why I keep them behind this Click image to enlarge :twisted: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated But shout it at them in German because life is also terrifying and confusing... |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
Where did you buy those brackets from please? Brilliant solution. I take it the bracket and arm are the kit to replace the original LR ones? |
As well as that Entreq solution (very elegant but 60 something quid) you can also just add a small extension (moves the pivot 26mm)
Click image to enlarge Make them yourself or X-Eng will soon be doing them for around a tenner. Forgot to say, the Entreq brackets are just a straight swap - Brendan (Leeds) is our "family" distributor and gives good deals :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated But shout it at them in German because life is also terrifying and confusing... |
