Home > Maintenance & Modifications > One door shuts....then another one opens :-) |
ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517 |
27th Nov 2012 5:28pm |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 |
If it helps with your rear window winder, take it off and turn it down 90 degrees, should stop it coming open!
27th Nov 2012 5:37pm |
cool like 6 o'clock? how do i get to the bolt...
27th Nov 2012 5:42pm |
If the door can swing open to 90 degrees and the wind (or kid) catches it, it goes too far and the forward edge puts a crease in the pillar. Don't ask me how I know Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
27th Nov 2012 5:45pm |
Would that be a LR 'camel toe'...
27th Nov 2012 5:51pm |
Thats it! Theres a little clip behind the handle that you need to flick out slightly to release the handle. A thin flat screwdriver should do it. Sorry, thats possibly the worst description possible!! |
AlpenAndes Member Since: 20 May 2011 Location: Currently Chile Posts: 128 |
Rather like something 4 or 5 o'clock, to let mother earth keep the winder down and your window up. Apparently that got forgotten with electric windows. Behind the winder is a spring/splint, however you call that in English, which holds it on that axle, take it out and you can take the winder off. BR Oskar |
27th Nov 2012 5:54pm |
Thank you - I will never see it the same way again Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
27th Nov 2012 6:16pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Get ready to catch the clip though. A knackered narrow flat bladed screwdriver or strip of steel with the end of the bent at a right angle is handy to hook behind the loop end of the clip.
Another tip for someone to rehash and be considered an expert Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
27th Nov 2012 6:18pm |
I tried repositioning them but it didn't help so I used a more "robust" approach:
Click image to enlarge As I bought decent black elastic cord and hid the knot inside the hollow of the handle, it actually isn't that obvious Haha - just noticed ti-fat did the same :rolllaugh: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... Last edited by ZeDefender on 27th Nov 2012 6:39pm. Edited 1 time in total |
27th Nov 2012 6:37pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19657 |
ZE - Dogs would love to chew that handle. Mine would anyway. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
27th Nov 2012 6:39pm |
Small children too - that's why I keep them behind this Click image to enlarge :twisted: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
27th Nov 2012 6:42pm |
Where did you buy those brackets from please? Brilliant solution. I take it the bracket and arm are the kit to replace the original LR ones? |
27th Nov 2012 6:46pm |
As well as that Entreq solution (very elegant but 60 something quid) you can also just add a small extension (moves the pivot 26mm)
Click image to enlarge Make them yourself or X-Eng will soon be doing them for around a tenner. Forgot to say, the Entreq brackets are just a straight swap - Brendan (Leeds) is our "family" distributor and gives good deals :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
27th Nov 2012 6:59pm |
