Home > Maintenance & Modifications > One door shuts....then another one opens :-)
ti-fat-man
United Kingdom 2011 Defender 110 Puma 2.4 USW Alpine White
Thumbs Up
Post #188912 27th Nov 2012 5:28pm
ti-fat-man
makes a huge difference to the accessabilty (sp!) does make you wonder why the first OME bracket and/or strap is so short...
Post #188914 27th Nov 2012 5:36pm
JeremyJ
If it helps with your rear window winder, take it off and turn it down 90 degrees, should stop it coming open!
Post #188915 27th Nov 2012 5:37pm
ti-fat-man
cool like 6 o'clock? how do i get to the bolt...
Post #188918 27th Nov 2012 5:42pm
ZeDefender
If the door can swing open to 90 degrees and the wind (or kid) catches it, it goes too far and the forward edge puts a crease in the pillar. Don't ask me how I know Sad Tell someone you love them today because life is short.
Post #188920 27th Nov 2012 5:45pm
ti-fat-man
Would that be a LR 'camel toe'... Wink
Post #188922 27th Nov 2012 5:51pm
JeremyJ
Thats it! Theres a little clip behind the handle that you need to flick out slightly to release the handle. A thin flat screwdriver should do it.
Sorry, thats possibly the worst description possible!!
Post #188924 27th Nov 2012 5:51pm
AlpenAndes
Austria 2010 Defender 110 Puma 2.4 SW Belize Green
Rather like something 4 or 5 o'clock, to let mother earth keep the winder down and your window up. Apparently that got forgotten with electric windows.
Behind the winder is a spring/splint, however you call that in English, which holds it on that axle, take it out and you can take the winder off.
BR
Oskar
Post #188925 27th Nov 2012 5:54pm
ZeDefender
Thank you - I will never see it the same way again Thud
Laughing Tell someone you love them today because life is short.
Post #188932 27th Nov 2012 6:16pm
Happyoldgit
Get ready to catch the clip though. A knackered narrow flat bladed screwdriver or strip of steel with the end of the bent at a right angle is handy to hook behind the loop end of the clip.
Another tip for someone to rehash and be considered an expert Whistle Steve.
http://forums.lr4x4.com
Post #188933 27th Nov 2012 6:18pm
ZeDefender
I tried repositioning them but it didn't help so I used a more "robust" approach:
As I bought decent black elastic cord and hid the knot inside the hollow of the handle, it actually isn't that obvious Whistle
Haha - just noticed ti-fat did the same :rolllaugh:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Tell someone you love them today because life is short.
Post #188941 27th Nov 2012 6:37pm
ZE - Dogs would love to chew that handle. Laughing Mine would anyway. Whistle Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #188942 27th Nov 2012 6:39pm
ZeDefender
Small children too - that's why I keep them behind this
:twisted:
Post #188948 27th Nov 2012 6:42pm
geobloke
Where did you buy those brackets from please? Brilliant solution. I take it the bracket and arm are the kit to replace the original LR ones?
Post #188951 27th Nov 2012 6:46pm
ZeDefender
As well as that Entreq solution (very elegant but 60 something quid) you can also just add a small extension (moves the pivot 26mm)
Make them yourself or X-Eng will soon be doing them for around a tenner.
Forgot to say, the Entreq brackets are just a straight swap - Brendan (Leeds) is our "family" distributor and gives good deals :thumbsup:
Post #188957 27th Nov 2012 6:59pm
