![]() | Home > My Defender > Lizzy |
| BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 928
Looks good with the tinting.
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
| steveww Member Since: 05 Jan 2022 Location: Malton Posts: 612
Busy weekend chasing funny noises. For a while there's been a strange creak cum rattle coming from the front footwell somewhere. A quick search on this site soon told me it's not uncommon and gave me a list of suspects to check. I found that one of the bonnet hinges was loose and the little bolt on the floor under the handbrake was rattling in its hole. I'd missed that sneak little blighter when I did the floor panels. Once everything was tightened up the noises were gone
While I had the tools out, I fitted a Nakatanenga rear door gas strut. https://www.mudstuff.co.uk/products/defender-rear-door-gas-strut It works really well but does just catch the internal trim panel and pops it off one of the fixings. On the plus side because it keeps the rear door under tension when shut, it's also stopped the rear door rattling so much. Of course with one source of noise eliminated many more now make themselves noticed. It would not be a Defender if it did not rattle a bit. |
| Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2347
Sounds good getting a few of those noises and jiggles sorted 👍
The rear gas strut shouldn’t foul anything - well mine doesn’t and it’s been fitted for years. Really great mod. It’d be interesting to see where it’s fouling if you can take a pic or two 👍[/i] |
Due to the wheel carrier and big wheels and tyres I had to fit the bracket on the door using the holes on the right to restrict the angle of opening. The body of the gas strut catches on the trim trim about half way through its arc.
Click image to enlarge |
Aha! Sorry I misread the description - I was referring to the later version which is mounted to the top of the door!
I prefer the neater in door installation.
Click image to enlarge Replaced the front seats with the Premium option. Very stylish and more comfortable. The old ones will be in the For Sale section soon. Keep your eyes peeled. |
| ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 481
You can’t beat those seats Steve, best option on many levels as far as I’m concerned. One of the best things I ever did 👍
Looks like you just need a cubby box with a deeper cushion now that will make a big difference to comfort as well. |
I gave Lizzy a service over the weekend. Changed all the oils, filters and greased up.
If you have the ORE wheel carrier don't forget to squirt some grease in there too. The front diff oil was quite dark compared to the rear diff oil. The gearbox oil was clear, I feel happy leaving this one longer next time. The transfer case was darker, I'll add the larger cooling sump to it soon. All ready for some summer time adventures now... |
Click image to enlarge A run out on a sunny Sunday |
| Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 732
Lovely 110 and a great photo, that looks like Harringworth viaduct in the background? 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
That's because it is the Harringworth viaduct.
Click image to enlarge A fun morning at Rockingham 4x4 course with Ed Cobley. I've done the course before but in a modern LR full of electrickery; just select mud and ruts. Great to see what you can do with a mechanical Defender. My favourite comment from Ed. The Defender has wade depth sensors. When it starts coming in the doors, it's too deep. |
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11091
