Home > Technical > 130 won’t go above 58mph |
Bradders130 Member Since: 27 Nov 2021 Location: Southampton Posts: 75 |
So Martin seems to have found the problem. I took the instrument cluster out and went for a drive up the motorway where it went straight up to 70mph without any hesitation. Pulled off and reconnected it and back down to 58 (56 on GPS).
So the issue now is, is the problem to do with the IPAC or the connection between it and the ECU (or something else). I’m quite happy to fork out for a new one, but not over the moon if it’s something else. Any thoughts chaps? |
20th Jul 2022 10:46am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6489 |
It means that the limiter is most likely to be in the ECU (a setting or a map).
The ECU wasn't receiving a speed signal (over CAN sent out via the cluster) so it didn't limit. Although it still could be an external limiter (one which modifies the pedal signal). This is because disconnecting the cluster will affect the shape of the speed signal - so if another device is monitoring the speedo sensor signal it could have also seen 0 mph and allowed full pedal action. Any sign of modified wiring at the instrument cluster connector or the harness to it? If you've got a Nanocom or similar, can you drive it and monitor the Acc Pedal Sensor Signal values? In the emulator this is in Puma Engine > Inputs > Speed Accelerator. As you hit the 58mph limiter, mash the pedal to the floor Do the sensor values go up to 100% or are they clipped to something lower? Martin 1988 90 Td5 NAS soft top 2015 D90 XS SW |
20th Jul 2022 11:00am |
Hold on - just remembered there is also a instrument pack speed limit.
In Nanocom emulator Instrument Pack > Settings > right green arrow. Should show a limiter page? 1988 90 Td5 NAS soft top 2015 D90 XS SW |
20th Jul 2022 11:03am |
Damn, if Martin hasn’t come up trumps, at least I think that it’s Martins fault
So I went into the instrument cluster menu of the Nanocom and pressed the 87mph button, although there isn’t a read out to say that, that is what it is set to. Anyway, I’ve just been up the motorway and that seems to have sorted it. Although I have no idea as to why it would have changed as there is no setting to drop the speed to 58 (which I think is actually 56). Maybe it defaults if the cluster is removed and did so when I removed it for that other pain in the neck immobiliser issue? Anyway, what a b****y nightmare. A pain in the a**e, which was actually a simple fix, and on this occasion, ignorance was not bliss!! A huge thank you to all who made contributions and suggestions… Martin, Blackwolf, Mdm, Bear100, mwestcrew, Barneyboy, Markb110, Jpboost, x4stp, landy Andy. I could not have sorted it without you and I’m very grateful. if I had all your addresses I would genuinely send you all a case of beer to show my appreciation! Thank you |
20th Jul 2022 1:18pm |
jpboost Member Since: 13 Apr 2021 Location: Gatwick Posts: 375 |
That's great news. Glad you've sorted it.
20th Jul 2022 1:23pm |
mwestcrew Member Since: 09 Dec 2019 Location: South Warwickshire Posts: 222 |
Glad you got it sorted. Martin on the money as usual. 2011 130 Utility Body
2005 110 Van |
20th Jul 2022 2:01pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16937 |
It's interesting that 15 years after the vehicle was launched we're still learning how it works and how to put it right!
Glad you're sorted, and thank you for one of the more interesting questions of recent months. |
20th Jul 2022 2:39pm |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1542 |
if i remember the conversation with them at the time it was to do with tacho regs were they fitted and as a bonus so they couldnt speed anywhere as they where always loaded to the max weight and top heavy
20th Jul 2022 2:48pm |
Barneyboy Member Since: 19 Nov 2014 Location: Oxfordshire Posts: 1583 |
Hi Bradders130 glad you got it sorted ready for Friday cheers Paul
20th Jul 2022 4:59pm |
Cheers you guys
20th Jul 2022 11:42pm |
