![]() | Home > Td5 > TD5 Clutch slip - damp FPR |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3331 ![]() ![]() |
You can buy a new "take off" spare wheel carrier from Twisted for around £50
You shouldn't need a new DMF at 60,000 miles |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 987 ![]() ![]() ![]() |
Swing away will take the weight off the door and hinges and they will both last much longer. The weight is transferred to the frame.
![]() Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) Last edited by 4RF RDS on 9th Apr 2022 9:43pm. Edited 1 time in total |
My one started leaking like a
The O/P's Defender has the later rear door which is much stronger and able to take the weight of the wheel.
So, although they are a nice accessory there's less need for a swing away wheel carrier. My 110 is on 140,000 miles and the door/hinges are still perfect |
Joncorry Member Since: 03 Apr 2022 Location: The Lake District Posts: 200 ![]() ![]() ![]() |
Just to close the loop on this… I took it to Henshall Engineering in Chelford whom I use to maintain my G4’s and he fitted the LOF HD clutch kit with new dual mass flywheel and clutch fork. He also popped a new rear main seal in and the assist pedal spring. It’s now superb to drive but sadly I have to sell it. It’s on eBay if anyone fancies it. 2009 90 commercial.
2003 110 G4 used in 03 and 06 events - its well travelled. 2002 Range Rover G4 Event car (Australian leg) 2008 Discovery 3 G4 UK Selections car 1968 Series 2a |
