Page 1324 of 1391 <123 ... 132313241325 ... 138913901391>
kenzle8a
Out fixing the electric fence since one of the horses worked out the battery was off and went in search of the feed room
Post #932171 2nd Dec 2021 1:27pm
kenzle8a
Post #932172 2nd Dec 2021 1:27pm
Ihod
United Kingdom 1998 Defender 90 300 Tdi ST Rioja Red
It's that time of year...
 Ian
MY1998 300Tdi 90 Hard Top (Now Soft Top)
MY2015 110 XS SW - Sold
MY2008 110 County USW - Sold
MY1962 Series IIa Truck Cab - Sold
MY1994 300Tdi 90 Hard Top - Sold
MY2001 TD5 90 Truck Cab - Sold
Post #932709 7th Dec 2021 12:02pm
L110CDL
lord-haggis wrote:
Cant beat a " in the field " pic Very Happy Clayton.
Keeper.
Post #932908 8th Dec 2021 10:41pm
Dinnu
An innocent little puddle turned out to be a 1 meter deep hole 😩
Tried the usual tricks of trying to fill the hole with rocks..but I could not pull myself out with one wheel barely touching the slippery surface. Time to call rescue 🤭
Luckily I was going very slow, so just a little bent bumper.. easy fix. Although I need to check the sill, as the side steps might have pushed it up a bit (door is rubbing now).
 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #933301 12th Dec 2021 6:39pm
Co1
Oops!! I hope the stainless lower grille is ok!! Wink
Post #933303 12th Dec 2021 7:08pm
Dinnu
Yeah...was an ooops moment. The grille is perfect..and not even dirty 😊
This pic should show that 🤓
Post #933306 12th Dec 2021 7:42pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Passed the annual inspection Very Happy Thumbs Up Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #933358 13th Dec 2021 9:54am
Replaced the ignition switch:
More details here: https://www.defender2.net/forum/post933318.html#933318 Darren
Post #933364 13th Dec 2021 10:10am
Naks
Finally got the double-din dash + new radio fitted, Madman neatly mounted on the side as well.
Post #933430 13th Dec 2021 4:08pm
johnnyha
1996 Defender 90 300 Tdi CSW Epsom Green
Ashbyandy wrote:
Just done my good deed today, had to tow local plod out of a field, after he got bogged down in mud up to rear axel level. Actually a mate of mine, so called me first, hoping all the other local plods wouldn’t here about it. Not much chance of that, already 2 other cars and 4 plods at the scene by the time I got there, he knows he’s in for some serious ribbing from his mates when he clocks off, 🤣,
Ashby Andy
Nice work
Post #933532 14th Dec 2021 12:54pm
Smyles_
Denmark
Naks wrote:
Hey Naks, any chance you could tell me how much room there is behind those side panels. Looking to install a rather deep temp/pressure gauge there myself but the whole truck is in pieces currently so can't find out myself Snigger
Gauge in question:
(the bend protected pipe is the limiting factor not the black pressure pipe) Stuart
Cummins 130 Build Thread
Instagram
58 130 Double Cab HCPU - Cairns Blue
04 110 Double Cab - Black (gone)
07 Audi RS4 Avant - Silver
Post #933540 14th Dec 2021 1:15pm
Stacey007
^ That looks pretty deep if you have the double din unit in also, its all a bit tight behind them.
The angle that gauge goes in looks to be the brass type connection would fowl the radio?
I will try and get a picture of my side panel as its quite easy to clip off (another job I need to do is fix it in better)
---------- My Defender job was Drive to Garage, MOT. Passed first time Smile --------
Post #933549 14th Dec 2021 2:18pm
Smyles_
Denmark
Thanks Stacey, would be very much appreciated!
No double din to worry about (personally think they look naff with all the tacky shiny plastic) and the large connector for the backlight is between the 2 and 3 o'clock position with the other two at 6 and 12 if that makes sense. Basically holding the gauge upside down in that photo so there is nothing on the left hand side as you look from the face side with the lengths of threaded rod being for mounting so can be lopped as required. So with everything being to the right I think I can bag a little more room Very Happy
Congrats on the MOT! Laughing
110 looking very classy with those mud flaps and no window tints Thumbs Up Stuart
Instagram
Post #933596 14th Dec 2021 9:34pm
Stacey007
OK not very scientific but there seems to be a lot more room than I thought, the angle must be enough to keep it away from the double din unit.
I used a cleaned yogurt pot to push in the hole... now I have a USB cable coming out of said hole so it was a quick job on the school run as I didn't want to push the cable back through.
To my surprise you have a fair bit of room. You can see the cable actually stopping it. it would go a bit further and worse case you could space it out at the front slightly with a large rubber washer?
I reckon you have a good 60mm Maybe more, I'm due out soon so when parked up will have another look.
Post #933803 16th Dec 2021 10:28am
