Page 1323 of 1394 <123 ... 132213231324 ... 139213931394>
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
karlp606 wrote:
Broonster wrote:
Busy few days! Fitted a new ORE wheel carrier and replaced the old, scabby steel wheel and ancient tyre with a new matching alloy & BFG tyre.
Also took out the front headlining, covered it, and put it back in. Not decided what I'll do about the sun visors yet though.
Also added ClimAir wind deflectors. Definitely the easiest Defender job I've ever done so far!
Lovely looking motor you have there, Ive just recieved my wind deflectors and got the drivers side slided in and fitted okat but the passenger side is very very tight the outer plastic seal which goes against the glass is very tight and I can get the top part of the deflector all the way up into the gap Im pushing the deflector up as Im stood on my side rail to stop me pushing the full door up on the hinge! Any fitting tips?
To help ease the deflectors into place I used a light spray of silicone. Worked a treat.
.....other brands are available Thumbs Up
Post #921213 12th Sep 2021 9:29pm
bodstruck
Final job on the new winch and bumper installation- fitting the rope.
Post #921224 12th Sep 2021 10:31pm
karlp606
United Kingdom 1997 Defender 90 300 Tdi CSW Firenze Red
Thanks man
Post #921249 13th Sep 2021 9:03am
excossack
Saturday was a trip to Gale Rigg, near Pickering for recovery duties on the Trackrod rally.
Also had entries from the Armed forces rally team and a new Defender Bowler 90.
A dry and dusty day in the forests. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #922954 27th Sep 2021 8:44am
karlp606
Fitted my door cards after spraying them black with vinyl paint, interior looks a 1000 times better.
Put all new door card fitting trim pieces in the door also, the rubber fixings, the pop off screws, luckily 90% of the plastic heads that the little black plastic screws fit over were not broken Smile
Post #922980 27th Sep 2021 10:29am
Any photos from the trackrod rally? Defender came in 28th if I recall the social media posts?
Post #922984 27th Sep 2021 10:46am
NickMSM
Fitted a Twisted steering guard, swapped all my Wipac LEDs for Perei 95mm rear and clear standard side/indicators at the front.
Post #923042 27th Sep 2021 4:52pm
karlp606
A satisfying weekend of Defender upgrades Smile ;
Secured the gearbox tunnel back to the floor pans, floor all nice and sealed now ready for the new exmoor trim carpet.
New seats popped in..
New rear reverse light fitted and connected. Definite improvement!
New LED headlights fitted also luckily my car already had the sidelight and indicator on spade connectors Smile.
No pics unfortunately.
Also decided to spray up the chequer plate on the side steps, thought Id give it a go as looking at swapping them out anyway so if went t*ts up no problem, but they have come up a treat! Sorry no before pics but you know what silver chequer plate looks like, here's the results;
I used a hammerite style spray paint which had an adjustable nozzle so got really coverage, probably needs another coat with a wet sand. I gave a the chequer plate a good sand before hand.
Going to look at touching up the rear cross member with this also and doing the rest of the chequer plate.
I wish all defender jobs went as easy!!!
Post #925244 10th Oct 2021 7:51pm
excossack
Monday managed to grab some time for a few jobs.
Checked oil/water/screen wash
Greased prop shaft joints
Replaced the water-in-fuel-filter sensor. Had to cut and solder fresh wires back in. But still dont get the water-in-fuel-filter dash warning light on.
I did notice that the sensor I replaced was not the same as the original. The original was like two little prongs, the new on was what looks like a brass screw. 1999 Defender TD5 110
Regards
John M0VAZ
Post #925464 12th Oct 2021 9:41pm
Naks
Stuck the PowerfulUK bonnet decal on
Post #925503 13th Oct 2021 1:10pm
excossack
Replaced;
Both rear shocks
Replaced both front wiper blades, spindles and wiper arms
Replaced the missing screws in the steering column shroud. 1999 Defender TD5 110
Regards
John M0VAZ
Post #928907 7th Nov 2021 3:31pm
nitram17
Like those steps. Where did you get them from?
Post #928982 7th Nov 2021 9:57pm
excossack
Changed gearbox oil
Fitted a headlamp upgrade loom. I have gone from 10.2v at the bulb to 13.xv at the bulb when in operation. Took the feed direct from the alternator and mounted the relays just behind the power steering reservoir.
A quick check the lights do look a lot brighter. 1999 Defender TD5 110
Regards
John M0VAZ
Post #931132 25th Nov 2021 5:31pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Fitted the bespoke seat covers to the rear seats to replace the lidl special that was there but as it’s winter time thought better try to protect them from the dog better. I also have the front and third row to fit but that will be another day. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #931141 25th Nov 2021 6:23pm
Ashbyandy
England 2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
Just done my good deed today, had to tow local plod out of a field, after he got bogged down in mud up to rear axel level. Actually a mate of mine, so called me first, hoping all the other local plods wouldn’t here about it. Not much chance of that, already 2 other cars and 4 plods at the scene by the time I got there, he knows he’s in for some serious ribbing from his mates when he clocks off, 🤣,
Ashby Andy
Post #931584 28th Nov 2021 5:54pm
