![]() | Home > Puma (Tdci) > Nanocom fails on a 2.2l Defender |
| nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 |
That's very disappointing have you taken this up with black box?
| landhank Member Since: 27 Oct 2021 Location: RLP Posts: 37
Yes, of course. That was my first step. They confirmed that the Nanocom is only working with 16-digit codes for the injector coding (which means its working up to MY2012 with Denso injectors only). The 2.2l engine comes with VDO/Continental injectors and they have a 6-digit code.
For me it looks like that the Nanocom is having trouble with the CAN bus communication on the newer models with the 2.2l engine. Trying to do a pilot correction is always coming up with an CAN-bus error. |
Thanks for alerting us later model defender owners to the problem! I Wonder given they new abput the problem if black box are being economical with the truth (by omission)regarding their products capabilities with later model defenders ?Perhaps in the interests of openness others that have found problems would like to comment?
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2541
Re original question, have a look at forscan ( as the 2.2 is a ford engine) ,reasonably priced and coupled with a quality obd2 reader that supports forscan should be able to code and pilot learn injectors for the 2.2. However worth confirming that with them before purchase. And checking out the forscan forum.
Re nitram17’s question on nanocom support for the 2.2. They state that the ALM unit fitted to 2.2’s is supported. However one member on here used it to set indicators to blink when activating alarm and in doing so immobilised the engine ! Now they may have rectified that issue with their latest beta software by adding a function that reinstates communications between the ALM and engine ECU. However it has raised concerns with me and I now have a lack of confidence in the nanocom ALM support. I have raised a few questions with BBS SPY on here re ALM support https://www.defender2.net/forum/topic68425.html and after no reply for a long while I also sent a pm, but that has not been read. This coupled to the above issues re injector coding etc is making me wonder how much support the nanocom provides for the 2.2 beyond what a basic obd2 app provides, especially if you add the forscan app as well. |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3649
Forscan does not work with 2.2. JLR have changed a few things and is not recognized by Forscan. I tried it.
Thanks Dinnu, I was going to buy a copy of forscan just to see if it works, but you have saved me a doing that. |
its a little disconcerting that they have not replied to your enquiry.....we really need to know if there is a problem with later defenders and their silence if im being honest is a little deafening! Diesel driver on here promotes group buys so perhaps he would like to comment! |
For me this means a bit of a headache because my Defender needs new injectors and I thought I was well equipped with a Nanocom. The bbs website even states that the coding works. Too bad.
Has anyone worked with Launch or Icarsoft diagnostics? |
| Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434
I have the BAS RRC (which is based on the IID tool as far as I can tell) and it is able to code the injectors on my 2015 without issue.
Perhaps the the bas tool or the iid would satisfy your needs? Disappointing about the nanocom. I was considering getting one for the alm, but it seems that there are too many unknowns, including this thread Last edited by Angus_Beef on 3rd Nov 2021 8:55pm. Edited 1 time in total |
| Julie Member Since: 07 Oct 2017 Location: La Réunion, Madagascar Posts: 589
I have the Nanocom and Ihave an early 110 with the 2.2L engine. Injector coding and pump relearn show up on my menu bar and Black Box indicate this function in their user manual (for the early birds at least) Although I've never tried ... Some jugdes say injectors are not wearing parts and they shall survive an engine's life (but that's another question) EURO5 engine's homologations are for 200 000 kms |
user manual p8
Injector Grades Reads and provides editing and writing capabilities for each of the four groups of 16 Hex injector grade characters as stamped on the injectors. Injectors are numbered from front to back, number 1 is at the front and number 4 is at the back end of the engine. Each injector has its own unique code. This code is used by the engine management as part of the fuelling control and must be entered correctly. Pump Learning Each injector connected to the engine management has different characteristics e.g. opening times, shutting times and these injector characteristics vary with fuel rail pressure. Normal Pilot Correction learning functionality is designed to learn changes to injectors over time, so it only allows incremental changes from previously-learned values. If injectors are changed, or cleaned etc, the difference may be substantial. Pilot correction learning may not be able to immediately access the appropriate values - it may take several engine cycles to reach the correct values. This will adversely affect emissions. The next time normal learning is done, pilot correction learning will immediately adjust to the appropriate value. The user must start the engine and run at idle while using this function. IF THE NANCOM DID NOT ITS JOB, YOU SHOULD GO IN TOUCH WITH BLACK BOX SOLUTIONS... Last edited by Julie on 3rd Nov 2021 8:13pm. Edited 1 time in total |
Yes, it shows up. But its not working. If you try to read out the injector codings, it shows you a 16-digit code which is not suitable for the injectors in a 2.2l.
If you try to do the pilot correction, it comes up with a CAN-fault. |
| philippr86 Member Since: 08 Sep 2017 Location: Frankfurt Posts: 26
Hi landhank,
yes same here. Just tried to run the pilot correction yesterday but just shows a fault message. Same thing with injector codes. Newest software installed of course. The tool I've got from BAS remap shows the correct injector codes. Also provides the pilot correction. Doesn't show a fault, but requires the engine to be switched off, which does not correspond to the Nanocom description. But I haven't been in contact with Pete Bell yet, to ask for clarification. Will let you know if I get some feedback... Phil |
Hi philippr86,
thanks for your message. Which tool from Pete Bell do i need? I think it will run because as i remember the Nanocom pilot correction requires a switched off engine as well before you are able to start the procedure (i did it on my 2.4l). Regards Landhank |
