![]() | Home > My New Defender (L663) > 21MY 90 D200 S |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3512 ![]() ![]() |
The 90 had its first trip to dealers today to investigate its mystery noise, no fault found was the result. I think me playing with the heat shield solved the issue as it’s never made sound since. 24MY 90 D250 HSE, Tasman Blue
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 ![]() ![]() ![]() |
Yes you have probably fixed it, another owner got LR assist out and he bent it too much where it caused it to rub elsewhere so he had to get them back out the following day to readjust it.
It’s now naked
![]() Click image to enlarge Fitted the load space tread plate ![]() Click image to enlarge And the pedals, a bargain from Brit Car, £32 if I recall. Powerful UK want £160 for the same thing and LR want £100. ![]() Click image to enlarge 24MY 90 D250 HSE, Tasman Blue |
Scrumps Member Since: 24 Feb 2021 Location: Somerset Posts: 109 ![]() ![]() ![]() |
J77,
Ref :- noise and the rear heat shield. We’ve had LRA out twice to ours and have raised the issue with LRCS. They have requested our dealer investigate and feedback their findings. The car is in today for that so we’ll see what happens. It looks clear when stationary but under load (braking or reversing up our drive) the rear subframe flexes on the mountings and fouls. You could see the rub marks on the rear coupling. It only needs shortening by about 3mm to totally clear the coupling - that’s what I’ve told the master Tech at the dealer. Scrumps 90 D250 HSE Tasman Blue 24MY L461 RRS Verasine Blue 05 TD5 90 CSW Cairns Blue 1967 MGB BRG 1944 Willy’s MB OD green 1942 Willy’s MB OD green |
Deleted - double post. 90 D250 HSE Tasman Blue
![]() I played around with mine and so far not a sound. 24MY 90 D250 HSE, Tasman Blue |
J77,
You fixing it part of the issue - expedient though it might be. We’ve been told by our friendly Master Tech that as many dealers as possible need to raise an “EPQR” form back to Land rover technical or nothing will get done. They need a “weight of evidence” that there is a problem before acting. Everyone with this issue needs to go down that route before a TSB or modified part is issued. Scrumps 90 D250 HSE Tasman Blue 24MY L461 RRS Verasine Blue 05 TD5 90 CSW Cairns Blue 1967 MGB BRG 1944 Willy’s MB OD green 1942 Willy’s MB OD green |
Deleted - double post (again). 90 D250 HSE Tasman Blue
Dealer checked it over when it went in, don’t know if they raised anything with LR.
It’s going back in 31st to get side steps fitted, this time I’ll be there in person so I’ll chat to them about it. 24MY 90 D250 HSE, Tasman Blue |
It seems LR Assist are getting quite skilled in bending things... ![]() Click image to enlarge |
Shelf fitted from New Defender Parts, handy for the phone sitting in.
Had a 290 mile road trip around Loch Lomond and Loch Linnie into Fort William, averaged 39mpg.
Seams that’s where the 90’s are hiding. A nice Black one at Firkin point. ![]() Click image to enlarge Also saw a White one and a Grey one with the square 24MY 90 D250 HSE, Tasman Blue |
A few photos of Loch Lomond
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Considering I deleted the centre console from my spec and LR chose to fit it anyway, it’s come in handy ![]() Click image to enlarge 24MY 90 D250 HSE, Tasman Blue |
£948 lighter but we now have side steps fitted. 24MY 90 D250 HSE, Tasman Blue
