Home > My New Defender (L663) > 21MY 90 D200 S
Page 9 of 12 <123 ... 89 101112>
J77
Looks like this could be the source of my noise, crawled under today took a few a photo to point the dealer in the right direction. Thanks to Digger2000 for the info
 24MY 90 D250 HSE, Tasman Blue
Post #901986 8th May 2021 12:01pm
J77
The 90 had its first trip to dealers today to investigate its mystery noise, no fault found was the result. I think me playing with the heat shield solved the issue as it’s never made sound since. 24MY 90 D250 HSE, Tasman Blue
Post #902382 10th May 2021 2:14pm
Digger2000
United Kingdom 2006 Defender 90 Other HT Tonga Green
Yes you have probably fixed it, another owner got LR assist out and he bent it too much where it caused it to rub elsewhere so he had to get them back out the following day to readjust it.
Post #902405 10th May 2021 4:31pm
J77
It’s now naked
Fitted the load space tread plate
And the pedals, a bargain from Brit Car, £32 if I recall. Powerful UK want £160 for the same thing and LR want £100.
Post #903728 18th May 2021 1:25pm
Scrumps
United Kingdom 2005 Defender 90 Td5 CSW Cairns Blue
J77,
Ref :- noise and the rear heat shield. We’ve had LRA out twice to ours and have raised the issue with LRCS.
They have requested our dealer investigate and feedback their findings.
The car is in today for that so we’ll see what happens.
It looks clear when stationary but under load (braking or reversing up our drive) the rear subframe flexes on the mountings and fouls. You could see the rub marks on the rear coupling.
It only needs shortening by about 3mm to totally clear the coupling - that’s what I’ve told the master Tech at the dealer.
Scrumps 90 D250 HSE Tasman Blue
24MY L461 RRS Verasine Blue
05 TD5 90 CSW Cairns Blue
1967 MGB BRG
1944 Willy’s MB OD green
1942 Willy’s MB OD green
Post #903785 18th May 2021 8:31pm
Scrumps
Deleted - double post. 90 D250 HSE Tasman Blue
1967 MGB BRG
Post #903786 18th May 2021 8:31pm
J77
Thumbs Up
I played around with mine and so far not a sound. 24MY 90 D250 HSE, Tasman Blue
Post #903798 18th May 2021 8:59pm
Scrumps
J77,
You fixing it part of the issue - expedient though it might be.
We’ve been told by our friendly Master Tech that as many dealers as possible need to raise an “EPQR” form back to Land rover technical or nothing will get done.
They need a “weight of evidence” that there is a problem before acting.
Everyone with this issue needs to go down that route before a TSB or modified part is issued.
1967 MGB BRG
Post #904145 20th May 2021 8:48pm
Scrumps
Deleted - double post (again). 90 D250 HSE Tasman Blue
1967 MGB BRG
Post #904146 20th May 2021 8:48pm
J77
Dealer checked it over when it went in, don’t know if they raised anything with LR.
It’s going back in 31st to get side steps fitted, this time I’ll be there in person so I’ll chat to them about it. 24MY 90 D250 HSE, Tasman Blue
Post #904167 20th May 2021 10:30pm
It seems LR Assist are getting quite skilled in bending things...
Post #904282 21st May 2021 1:11pm
J77
Shelf fitted from New Defender Parts, handy for the phone sitting in.
Post #904359 21st May 2021 9:19pm
J77
Had a 290 mile road trip around Loch Lomond and Loch Linnie into Fort William, averaged 39mpg.
Seams that’s where the 90’s are hiding. A nice Black one at Firkin point.
Also saw a White one and a Grey one with the square 24MY 90 D250 HSE, Tasman Blue
Post #905645 29th May 2021 8:19pm
J77
A few photos of Loch Lomond
Considering I deleted the centre console from my spec and LR chose to fit it anyway, it’s come in handy
Post #905771 30th May 2021 10:01pm
J77
£948 lighter but we now have side steps fitted. 24MY 90 D250 HSE, Tasman Blue
Post #905843 31st May 2021 1:59pm
