![]() | Home > Faults & Fixes (L663) > Intelligent AWD only drives in 2WD |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3475 ![]() ![]() |
Yeah my one has the diff glitch, constantly flicking between open and closed. 24MY 90 D250 HSE, Tasman Blue
![]() It’s going in on Monday to investigate the mysterious rubbing noise, hopefully nothing too serious. 24MY 90 D250 HSE, Tasman Blue |
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 ![]() ![]() ![]() |
Get them to check the heat shield for the prop isn’t touching the rear flange. Common problem with the 90 and only needs to be repositioned.
![]() I’m beginning to think it’s something like that as the noise is intermittent and when the AA checked the brakes they were clean. 24MY 90 D250 HSE, Tasman Blue |
Had crawl under the 90 and I think the heat shield touching the prop is a good shout. It looks pretty close.
What’s made my day though, is it has Defender engraved on the underbody protection, It’s little things in life ![]() |
jmac Member Since: 04 Feb 2021 Location: Scotland Posts: 14 ![]() ![]() |
Just checking that these are the right parts before I order? https://www.lrparts.net/lr149775-finisher-...-item.html Is it the same part for both left and right side? |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 ![]() ![]() |
They are different left and right
I think they end in 75 and 76 The link is correct part Look at powerful web site he has them and shows the part numbers |
The latest software update 2.0.10e has fixed my driver display e differentials glitch fault! I’m over the moon with the update, I can now see all sorts of information on the differentials 4x4i screen now that was not there before this update. Very happy chap today ![]() |
What sort of information?? Photos?
I could see things just 2 screens would not always show same info. I am trying to install the latest update now - but it has failed 3 times this morning - reset Pivi Pro and now have it on charge to see if that helps before another try in an hours time.. THANKS |
Now showing wheel slip and suspension information (possibly more that I don’t know yet) it’s like I have a brand new vehicle. Haven’t tested it properly I just downloaded it last night and had to move my car for the builders working on my house this morning, then I noticed additional screen information on the 4x4i which wasn’t showing before the update. Great update
Mines yet to receive any updates. 24MY 90 D250 HSE, Tasman Blue
Well after 5 or 6 goes the software updated.
Just took it for a drive and the Diff Screens (dash and pivi) still show different information and the ECO screem middle number is still 1 and does not change. ![]() ![]() |
Can't help thinking SOTA is just JLR doing a Huckleberry Finn on owners...
