![]() | Home > Puma (Tdci) > Britpart one price halfshafts |
Griff90bowler Member Since: 24 Feb 2021 Location: Cowbridge Posts: 137 ![]() ![]() |
Sorry even Bowler 😂😂
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Britpart do the complete kit if you need it, gaskets and bolts. You're better off changing them for cap head bolts (high tensile), they're much easier to get out as you've got more clearance around them.
SJM2018 Member Since: 06 Jul 2018 Location: Bristol Posts: 296 ![]() ![]() ![]() |
I used:
BX110095M.L8 x 2 (like others have said, there are better bolts to use) 571752.Z8 x 2 LR072977.C8 LR072976.C8 I also used some left over diff oil to help stick the gasket in place and smear over the splines / where the bearing sits; Some "Big Wipes" to clean the mating surfaces; and Some copper grease for the wheel nuts. I jacked one side at a time, so the hubs didn't move too much and I didn't lose any of the diff oil. 2011 CSW XS 90 |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 778 ![]() ![]() ![]() |
Thanks, blackwolf! I just wanted to be sure I had everything once the time comes and get it all done in one go! ![]() |
FD7 Member Since: 16 Feb 2021 Location: Midland Posts: 185 ![]() ![]() |
Those who've had them fitted, how long have you had them on for (approx mileage)?
Or range of mileage before the original 2 piece variants fail? |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
I fitted 300tdi disco single part ones to mine, noticeably thinner and lighter than the standard 90 2 part ones but removed more play.
As I don't abuse it off road or have an LS conversion so I'm confident they will be just fine. DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 401 ![]() ![]() ![]() |
Fd7
I fitted mine (britpart) two years ago and have covered 19000 miles without any issues. To be fair, thats hardly any off road use. ![]() |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3726 ![]() ![]() ![]() |
Done about 10k on mine with plenty of off road use. No issues at all.
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 343 ![]() ![]() ![]() |
I fitted mine around 2 years ago, but only put 10k miles on during that time.
