Home > Puma (Tdci) > Britpart one price halfshafts
Page 2 of 2 <12
Griff90bowler
Wales
Sorry even Bowler 😂😂
Post #891732 16th Mar 2021 8:41am
HardCharger wrote:
When switching out to the one piece shafts, are there any other parts required during the procedure? (seals, new bolts, gaskets, etc.?)
This is already on my to-do list and I want to make sure I have all the necessary items before I attempt the work. Won't do to have it all apart only to find out that there are missing parts.
Drive flange paper gaskets needed, but that should be all, unless you have problems with the drive flange bolts.
It is about a simple a job as you can get. Unbolt drive flange, extract old shaft, insert new shaft, bolt drive flange.
Post #891733 16th Mar 2021 8:49am
williamthedog
Britpart do the complete kit if you need it, gaskets and bolts. You're better off changing them for cap head bolts (high tensile), they're much easier to get out as you've got more clearance around them. Thumbs Up
Post #891741 16th Mar 2021 9:22am
SJM2018
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Aintree Green
I used:
BX110095M.L8 x 2 (like others have said, there are better bolts to use)
571752.Z8 x 2
LR072977.C8
LR072976.C8
I also used some left over diff oil to help stick the gasket in place and smear over the splines / where the bearing sits;
Some "Big Wipes" to clean the mating surfaces; and
Some copper grease for the wheel nuts.
I jacked one side at a time, so the hubs didn't move too much and I didn't lose any of the diff oil. 2011 CSW XS 90
Post #891761 16th Mar 2021 10:11am
HardCharger
Thanks, blackwolf!
I just wanted to be sure I had everything once the time comes and get it all done in one go! Thumbs Up
Post #892100 17th Mar 2021 2:30pm
FD7
2006 Defender 90 V8 Petrol ST Auto Chawton White
Those who've had them fitted, how long have you had them on for (approx mileage)?
Or range of mileage before the original 2 piece variants fail?
Post #893110 21st Mar 2021 10:29pm
LR90XS2011
I fitted 300tdi disco single part ones to mine, noticeably thinner and lighter than the standard 90 2 part ones but removed more play.
As I don't abuse it off road or have an LS conversion so I'm confident they will be just fine. DEFENDER 90 TDCI XS,
Post #893131 22nd Mar 2021 8:19am
Vitesse
Fd7
I fitted mine (britpart) two years ago and have covered 19000 miles without any issues. To be fair, thats hardly any off road use.
Thumbs Up 2015 90 XS Santorini Black
Post #893169 22nd Mar 2021 1:42pm
Co1
Done about 10k on mine with plenty of off road use. No issues at all.
Post #893258 22nd Mar 2021 7:59pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
I fitted mine around 2 years ago, but only put 10k miles on during that time.
Post #893278 22nd Mar 2021 9:30pm
Page 2 of 2 <12
