Home > Wheels & Tyres > Wheels/Tires allowed by Conformity Certificate
mattia.CH
Switzerland 2009 Defender 110 Puma 2.4 SW Keswick Green
I am facing a moment of panic as I recently ordered a set of Sawtooth wheels (7x16xET20) but my certificate of conformity (COC) only lists 7x16xET33 wheels.
I've been told by the Swiss MOT that as a consequence, I'll need to show up with tons of paperwork and have the new ones evaluated and approved.
I guess my questions is : why aren't those wheels showing up on the COC?
It seems to me that they should be among the wheels that LR used to put on this car (it's a 2009 Puma, pretty basic version):
Here is a screenshot of the aforementioned COC (highlighted in red the wheel part):
Post #891566 15th Mar 2021 3:11pm
chek
Switzerland 2016 Defender 90 Puma 2.2 SW Havana
I went through this in Zurich with the ANR Classics from Nakatanenga. I had to provide a DTC appprovement (CHF 180.-) and a confirmation from the manufacturer of the wheel (CHF 50.-).
Is this about the original LR-Sawtooth or a copy?
Post #891591 15th Mar 2021 4:37pm
I'd imagine it's because those particular wheels were never available for a regular vehicle of that age. Despite them being very common now, they were originally only available on a handful of special editions. Darren
Post #891594 15th Mar 2021 4:40pm
mattia.CH
A copy. To be honest I'm even willing to go OEM if only I could find them
Post #891596 15th Mar 2021 4:47pm
BADCADI
Switzerland 2010 Defender 110 Puma 2.4 CSW Alaska White
How about putting the original wheels on the car for the MFK, and then switch back to the aftermarket Sawtooth?
Post #891598 15th Mar 2021 4:51pm
mattia.CH
Apart from the hassle of doing that, this country is pretty strict - if they stop you, or you have an accident, you can get in serious trouble
Post #891600 15th Mar 2021 4:53pm
chek
I'd suggest to contact someone who's experienced in this. For me, it was the 4x4 Manufaktur (miriam*at*4x4manufaktur.ch) who provided me with all neccessary paperwork. She speaks french me guess. Good luck!
Post #891603 15th Mar 2021 5:05pm
mattia.CH
Thanks for the info, I'm quite unaware of the DTC approvement. What is that?
I can get in touch with Britpart in the meantime and see whether they can provide a doc for the wheel itself.
Maybe the have previous cases in CH regarding this
Post #891604 15th Mar 2021 5:05pm
mattia.CH
Thank you so much, this is great info!
Post #891606 15th Mar 2021 5:08pm
Dinnu
The 33mm offset where already offered for long time with the freestyle rims. They went to North America no issues.
I checked the CoC for my 2012, and I have the 33mm offsets listed.
I hope this can help you.
Edit.. Owe I see you need the 20mm, but is also listed, just 3 lines below.
 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #891608 15th Mar 2021 5:22pm
mattia.CH
thanks Dinnu
as pointed out earlier in the topic, mine is a 2009 and those specs were probably added to later models
Post #891610 15th Mar 2021 5:24pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Tires and rims depend most probably on the type approval
which is e11*2007/46*0133*02 for MY2012
And shall be e11*2007/46*0133*00 in your case
Post #891997 16th Mar 2021 11:28pm
mattia.CH
This is eventually what I did. Mirjam was very helpful and managed to get me the wheels and the docs needed.
Got my MOT check in a couple of weeks to approve the new setup and hopefully everything will be fine.
The new setup looks exactly like I wanted it. now it's full power on rust management Laughing Laughing
Post #907170 10th Jun 2021 8:58am
chek
Looking good! 👍
Post #907175 10th Jun 2021 9:06am
mattia.CH wrote:
rust management
One of the joys of owning a Defender Rolling with laughter Darren
Post #907176 10th Jun 2021 9:10am
