![]() | Home > Wheels & Tyres > Wheels/Tires allowed by Conformity Certificate |
chek Member Since: 17 Sep 2015 Location: ZRH Posts: 183 ![]() ![]() ![]() |
I went through this in Zurich with the ANR Classics from Nakatanenga. I had to provide a DTC appprovement (CHF 180.-) and a confirmation from the manufacturer of the wheel (CHF 50.-).
Is this about the original LR-Sawtooth or a copy? |
I'd imagine it's because those particular wheels were never available for a regular vehicle of that age. Despite them being very common now, they were originally only available on a handful of special editions. Darren
mattia.CH Member Since: 29 Dec 2020 Location: Lausanne Posts: 53 ![]() ![]() ![]() |
A copy. To be honest I'm even willing to go OEM if only I could find them |
BADCADI Member Since: 30 Dec 2020 Location: Munich Posts: 32 ![]() ![]() ![]() |
How about putting the original wheels on the car for the MFK, and then switch back to the aftermarket Sawtooth?
Apart from the hassle of doing that, this country is pretty strict - if they stop you, or you have an accident, you can get in serious trouble |
I'd suggest to contact someone who's experienced in this. For me, it was the 4x4 Manufaktur (miriam*at*4x4manufaktur.ch) who provided me with all neccessary paperwork. She speaks french me guess. Good luck!
Thanks for the info, I'm quite unaware of the DTC approvement. What is that? I can get in touch with Britpart in the meantime and see whether they can provide a doc for the wheel itself. Maybe the have previous cases in CH regarding this |
Thank you so much, this is great info! |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3605 ![]() ![]() ![]() |
The 33mm offset where already offered for long time with the freestyle rims. They went to North America no issues.
I checked the CoC for my 2012, and I have the 33mm offsets listed. I hope this can help you. Edit.. Owe I see you need the 20mm, but is also listed, just 3 lines below. ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
thanks Dinnu
as pointed out earlier in the topic, mine is a 2009 and those specs were probably added to later models |
Julie Member Since: 07 Oct 2017 Location: La Réunion, Madagascar Posts: 589 ![]() ![]() ![]() |
Tires and rims depend most probably on the type approval
which is e11*2007/46*0133*02 for MY2012 And shall be e11*2007/46*0133*00 in your case |
This is eventually what I did. Mirjam was very helpful and managed to get me the wheels and the docs needed. Got my MOT check in a couple of weeks to approve the new setup and hopefully everything will be fine. The new setup looks exactly like I wanted it. now it's full power on rust management ![]() ![]() ![]() Click image to enlarge |
Looking good! 👍
One of the joys of owning a Defender ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
