Home > Puma (Tdci) > Rushing fan noise under acceleration
Packster82
2013 Defender 110 Puma 2.2 CSW Keswick Green
Hi, I’ve suddenly developed a whooshing noise that goes up and down with the level of acceleration, the noise sounds like the heater fan blower but it’s not. Would I be right in saying it may be a crack in the turbo hose? I’m Only basing this on some basic research and from searching previous forum posts. I did hit a track pothole at speed (unintentionally!) which was quite a big bump, the blowing noise didn’t happens straight away but probably 10 minutes Later...any suggestions appreciated.
Post #879984 21st Jan 2021 6:53pm
Devon-Rover
If it sounds like a mini hurricane then yes it's likely to be a hose. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #879989 21st Jan 2021 7:14pm
whiteley5
I had something similar recently after hitting a pothole. It was a cracked inlet manifold.
Post #880020 21st Jan 2021 10:18pm
Packster82
I’m a bit out of my comfort zone on this as the leak isn’t obvious, will have to drop it in! I’ll update for everyone’s info but thanks for the input.
Post #880095 22nd Jan 2021 11:26am
hank
Few things to check here - with reference pictures https://www.defender2.net/forum/topic61960.html > 110 XS Double Cab
Post #880098 22nd Jan 2021 11:42am
PCM
I had exactly the same issue and whooshing noise.
Drove it around for a few more days confused until the light came on and the vehicle lost power.
Was a hole in one of the intercooler hoses. Replaced with silicone hoses.
A real knuckly scraping job to do the lower elbow but ok to do. Loads on info on here if you fancy giving it a bash.
Post #880235 23rd Jan 2021 1:41am
